Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 11-21-2007, 02:40 PM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default 1st Veneer Attempt. Questions…
OK guys, here’s the plan…
I’m going to make a 2ft tall plant stand using rail / stile and panels. I’m going to use 2x2 Oak from home cheapo for the rails / stiles and a veneered panels (for the panels obviously). I’m not going to have to do anything fancy since the edges of the panels are going to be hidden in the rails / stiles. The panels are going to be about 6” x 20”. Would ˝” MDF be a good substrate? Of course I’m going to veneer both sides to avoid warping. My thought was to use this beech birds eye birch since it should contrast with the red oak nicely (and its cheep)
http://www.veneersupplies.com/produc...oducts_id=4580
Will this be easy to work with for a n00b like me?
What would be a good glue to use? I was just thinking titebond II (since this is a light colored veneer) and lots of weight.
Tell me what you think…
Nickbee is offline   Top - Reply with Quote
Old 11-21-2007, 03:21 PM   #2
curiousgeorge
Supreme Forum King
curiousgeorge's Avatar
First Name: George
curiousgeorge is on a distinguished road
Hi Nickbee,
I don't think I would use any MDF on a plant stand if there will be any watering of the plants involved or used outside. That stuff just swells up and/or disintegrates when wet. Why not just use 1/4" oak ply for the panels instead?
If you want to use a different veneer you could just apply it to the oak ply panels. If it is for outside use you should use Titebond III or contact cement.
Applying veneer isn't all that hard you just have to be sure to get all the bubbles out using a roller of some sort and apply even pressure on the surface while the glue/cement is drying
George
For those who haven't already done so...
PLEASE! PLEASE! Fill in your first name and location in your profile.
curiousgeorge is online now   Top - Reply with Quote
Old 11-21-2007, 03:50 PM   #3
Nickbee
Forum Geek
Nickbee's Avatar
this will be used inside with a pot and pot saucer. So it should not be getting wet (but you never know)...
I wanted to use something to contrast with the oak... that's why I had the idea of the light colored veneer...
Old 11-21-2007, 08:50 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
I think if you seal it good with your finishing, including ends of legs, etc., you will be OK.
Seal everything... everywhere...
MDF does NOT like moisture... it will merely fall apart...
Joe Lyddon is offline   Top - Reply with Quote
Old 11-21-2007, 09:09 PM   #5
Nickbee
Forum Geek
Nickbee's Avatar
okay!!!! sealing is related to other questions I have.
The thing is going to be rails and stiles with the veneered panels. 4 2x2's in the corners are going to make up the rails (or are those the stiles?)... So should this get finished all together after it gets glued up? Is it ok that just the outside surfaces are getting finished? Once it's glues together the inside won't be accessible. I plan to use some kind of poly.
Also if I use MDF with the veneer should I glue in the panel or leave it "floating"? AS you can tell this project will have lots of firsts for me. It will also be my 1st project on my new router table.
Walnut Burl Box Build Along (1st Veneer Project) Nickbee Show N' Tell 38 03-18-2008 06:17 AM
My first attempt harrysin Woodturning and Lathes 17 03-10-2008 07:55 AM
Help with veneer plywood edge profile magicman22 General Routing 12 10-10-2007 04:13 PM
Applying Veneer s7horton The Finishing Touch 11 01-10-2007 08:37 AM
Applying Veneer fibertech Tools and Woodworking 7 11-25-2005 03:59 PM
