Thread Tools Display Modes
Old 11-25-2004, 08:58 AM   #1
cable-guy
Jr. Member
cable-guy is on a distinguished road
Default Measurement pins????
I just watched the dvd on the new Porter Cable 890 series routers. Bob and Rick have an insert where they show how to build a router table. In one of their steps they were setting the router for a 1/4" depth and he pulled out a little metal square pin and set the depth with that. This may be a VERY stupid question but what was that and where can I get a set??
Sorry if this comes across as completely ignorant .
cable-guy is offline   Top - Reply with Quote
Old 11-25-2004, 09:46 AM   #2
Scotty
Jr. Member
Scotty is on a distinguished road
This was one of the 5 piece set of brass measurement sticks that can be used quickly to measure your depth of cut on your router or table saw. I just bought a set of them at the Calgary wood show from Oak Park Ind. I've used them several times already and find them really useful. It is so much easier to just put one of them next to your bit and get the right height right away. The set comes with sticks measuring 1/8", 3/16", 1/4", 3/8", 1/2". They are made of brass so if you touch the carbide too ahrd it won't damage it. Just go to the catalogue and find them. By the way, I got the same router a while ago and really like it (and the video). I'd like to get your impressions of it and why you chose it.
Scotty
Scotty is offline   Top - Reply with Quote
Old 11-25-2004, 10:01 AM   #3
hcbph
Dedicated Member
hcbph is on a distinguished road
CAble-guy
I'm assuming they are just using some pieces of square stock. Check either at your local hardware store or metal supply store. Personally, I prefer using a veneer caliper to measure depth of cut.
hcbph is offline   Top - Reply with Quote
Old 11-25-2004, 12:22 PM   #4
bmb in ab
Member
bmb in ab is on a distinguished road
A similar set is available at Lee Valley. It also includes a 1-2-3 block.
Lee Valley Set Up Blocks
bmb in ab is offline   Top - Reply with Quote
Old 11-25-2004, 06:25 PM   #5
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Those brass bars are available from Oak Park, for a reasonable price. They save a lot of time when setting up.
I hope I helped, Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 11-25-2004, 08:26 PM   #6
cable-guy
Jr. Member
Thanks guys. I knew they had to be somewhere. Scotty, I'll let you know how things go. I've got the next three months of nothing but shop time.
Old 11-26-2004, 05:44 PM   #7
cfm
Dedicated Member
cfm is on a distinguished road
I purchased the blocks from a local hardware store. The are sold as motor shaft key ways. They are not brass and the specs are dead on. Since they are not brass, they cost about 1/3.
Hope this helps
cfm
(Posted earlier)
cfm is offline   Top - Reply with Quote
Old 11-27-2004, 12:41 AM   #8
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Hope this helps
cfm
(Posted earlier)
The reason brass is used is because it will not damage router bits. Keyway stock is steel and will damage bits.
ejant is offline   Top - Reply with Quote
Old 11-27-2004, 07:34 PM   #9
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You can also find the 5 piece brass set at Rockler.
Old 11-27-2004, 07:45 PM   #10
cfm
Dedicated Member
True, steel bars will damage router bits. These bars are somewhat harder than brass and less harder than Tempered Steel. After using the bars, they go into the pocket or in the drawer. There are a lot of tools that are used around routers, saws, drill presses and many other power tools that can cause damage to the tool or to the operator. Use with caution.
The 1-2-3 block refered to earlier is made of steel where the smaller blocks are made of anadiozed aluminum.
There are always alternative methods to consider - pro and con. FWIW :-).
IMHO
cfm
Knife pins or rivets BrianS Tools and Woodworking 4 08-05-2008 09:39 PM
Starter pins gary125 General Routing 2 05-06-2008 08:02 PM
Rockler Router Table Measurement??? Rodallg Table-mounted Routing 6 02-10-2008 05:36 PM
Leigh Jig & Tails on Edges (vs. pins) FlyMaster Jigs and Fixtures 2 10-16-2007 10:10 AM
Using Key Stock For Measurement wlbusby Introductions 2 01-23-2007 10:12 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
