| | #1 |
| Registered User | hi just getting in to using the router. tryed to make a box with finger joints using a 3/8 spacer fence and bit the joints don't fit tight what am i doing wrong the space between the bit and fence is 3/8 help thank ron |
| | #2 |
| Router King Supreme Forum King | You have to adjust the space from the bit to the fence rail. I believe you have to make the space larger by moving the rail away from the bit. Experiment with some scrap wood. It may be your bit is not exactly 3/8.
__________________ |
| | #3 | |
If the joint is loose then the spacing is smaller then it should be. For a reference I made a couple of sketches this morning and they are attached. Hope this helps. Ed | |
| | #4 | |
| Registered User Dedicated Member | Quote:
It didn't take long before I realized that making small adjustments to the settings made all the difference in the end result. Of course you want to use scraps that are the same dimensions as the final work piece. Hope this helps cfm | |
| Incra Ultra How-To (Box Joints + Other Stuff) | Nickbee | Show N' Tell | 5 | 01-21-2008 08:14 AM |
| Finger Joints | J0B00 | Jigs and Fixtures | 18 | 08-24-2007 02:19 AM |
| Box Joints | reible | General Routing | 4 | 05-03-2006 09:44 AM |
| Drawer joints - Box vs. Dovetail vs. ??? | ChevyNomad | General Routing | 2 | 01-14-2005 10:20 AM |
