| | #1 |
| Registered User New Member | If you have to cut a project piece less then 48 inches in length from a full sheet of plywood, should the piece be layed out lengthwise or widthwise? Also, is there any general consensus as to how a cut diagram is to be layed out when pieces are 48 inches or less in length? |
| | #2 |
| Retired Moderator Supreme Forum King | In my opinion you would want to take advantage of the exterior grain, afterall it's still wood and you would want some conformity in the grain or at least I try to on plywood products, especially if it is a nice plywood or a hardwood veneered plywood. Get the grain running the right direction for your project is what I would do. As far as cutting it doesn't make much difference since the plys are stacked and alternated. Corey
| Fastest Bit for cutting 1/2 Plywood??? | nicksorenson | Router Bits - Types and Usage | 2 | 06-02-2008 05:19 PM |
| Cutting boards for gifts.... | gad5264 | Project Plans and How To | 13 | 10-19-2007 11:13 AM |
| Cutting dados on a router table | paulcomi | Table-mounted Routing | 6 | 08-05-2006 10:52 PM |
| Cutting slots to overlap plywood panels | keylime48 | General Routing | 4 | 11-23-2005 10:15 PM |
| cutting plywood on a 45 with a router | joe carter | Tools and Woodworking | 2 | 10-24-2005 06:00 AM |
