Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 06-29-2007, 09:39 AM   #1
simplenik
Forum Geek
simplenik is on a distinguished road
Default "Lo-tech" table saw blade alignment
Good day
If you remember the caliper from the "Caliper modification", I'm using it also to check the table saw "blade - miter slot - rip fence" alignment.
Usually, when you check the blade alignment you check it across some 8" of the blade.
I extended the blade line by 3 and by doing so, multiplying the error by 3.
You can use any Straight Edge after checking that it is straight and the thickness is consistent all along (the straight edge on the pictures is, part of my rip-fence).
I would suggest to put some spacers (1/32") below the two boards and the straight edge before clamping them to the blade and remove them after clamping.
That way, when you adjust the table, the blade and the straight edge position will not be effected due to friction or whatever.
Regards
niki
simplenik is offline   Top - Reply with Quote
Old 07-08-2007, 06:06 PM   #2
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
First Name: Mark
Mark is an unknown quantity at this point
Wow, thanks for sharing!
Mark,
Administrator and Technician of RouterForums.com
RouterWorkshop.net - Get more out of your router!
Mark is online now   Top - Reply with Quote
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 11:57 PM
Table saw blade guard? Birch Tools and Woodworking 1 04-21-2007 12:56 PM
Table saw blade and adjustment ? rh111 Starting Off 1 11-27-2006 09:31 AM
Table Saw Blade Replacement Del Delaplante Starting Off 3 09-27-2005 06:42 PM
