Rate This Thread - Level Garage floor.
Thread Tools Display Modes
Old 07-08-2007, 01:13 PM   #1
lablover
Forum Fanatic
lablover is on a distinguished road
Default Level Garage floor
I now have the complete 2 car garage for my shop. Deal is I have to clean off the wifes car in the winter
Anyway, I hate that the concrete floor slopes down towards the garage door. I know this is needed for water etc but I want to make it level. Cement is not an option. I'd like to install plywood to make it easier on the feet and back.
What would be a good way to level it? I was thinking press treated sleepers and shimmed to make them level? Glues down with const adhesive?
Anyone have any other ideas?
Thanks guys
Joe
lablover is offline   Top - Reply with Quote
Old 07-08-2007, 05:05 PM   #2
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
Mark is an unknown quantity at this point
Bump.
Mark,
Administrator and Technician of RouterForums.com
Contact RouterForums.com
Refer a friend to RouterForums.com!
Mark is offline   Top - Reply with Quote
Old 07-08-2007, 09:42 PM   #3
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Is your floor poured inside the walls, or was the slab poured and then the garage built on top of it? If the garage was built first, and then the floor poured, you can actually level the floor by raising the low point. Not sure of the exact science behind it, but several contractors here drill holes in the concrete and pump concreted underneath it to raise the floor. Barring that, then your method should work just fine.
Of course, the raising won't do you any good if the floor was poured that way, but it does work well for slabs that have sunk.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 07-08-2007, 10:49 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Lablover
I know this can be a PIA but this could be and will be a expensive job
It maybe cheaper to add on a side shop to the garage and just let the floor be.
3 walls and a roof will be cheaper than a floor workover....if you have the room on the side of the garage....or on the back side of the garage...it just takes some 2 x 4 x 8ft. to make the frame and a bit of roof work and you will have a wood shop and your wife will have a garage this winter...
Thanks guys
Joe
Old 07-09-2007, 05:13 AM   #5
lablover
Forum Fanatic
I wish I had the room to add on. No can do.
The garage is attached to the house and was built after the slab was poured. I;m going to price it out just to see. The bigest hurdle will makin it level.
We will see
Joe
Old 07-09-2007, 07:45 AM   #6
kp91
Forum King
kp91's Avatar
You said the garage is yours, so do you have to move your machines much anymore? If you can leave them stationary, then level the machines out only. A lot of them have means to be made level. If you have to move them a lot, shim them on the mobile bases, and then lay out marks on the floor where you use them. This will make it easier to get them back level should you have to move them to bring Momma's car inside.
1 John 1:9
Old 07-09-2007, 08:30 AM   #7
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
. . . Cement is not an option. . . .
That's a shame -
because the simplest thing to do -- assuming you want it permanently level -- would be to put a dam across the front of the garage (just behind the door if you didnt want to have to make adjustments to it) then pour either self leveling compound - as the name implies - it goes on thin enough that it seeks its own level.
Or if you didnt mind doing a little minor trowel work -- sand topping mix is great for smooting off and leveling up to 2".
I definitely AGREE with you on the foot and back issues that cement aggrivates -- having recently poured a cement floor in my garage/shed/shop. It was formerly dirt (try sweeping up sawdust off THAT).
Drugstore Cowboy is offline   Top - Reply with Quote
Old 07-09-2007, 08:59 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Because it's woodworking shop you want it does'nt need to be a slab it can be a deck type add on... by removing a window in the garage you will have a door way to the shop from the garage....
We will see
Joe
Old 07-09-2007, 09:08 AM   #9
lablover
Forum Fanatic
Did some measuring this morning and it slopes 4.5 inches in 20 ft. Wow..Darn tools want to scoot out the door down the driveway. I was thinking of cutting each 2x4 and a few 2x6's each one..ughhhhh..But then again, I dont see any reason each one has to touch the cement. I could frame it like a house would be (floor that is) the joists just float over a certain width (like over your basement) This would save me from having to cut each joist. I think!!!..No wait..I'd still have to cut each one because they would hit the floor...Aghhhhhhh
Whats a good way to secure 2x4's and 2x6's to cement???
Joe
Old 07-09-2007, 09:19 AM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Joe
That's a big drop WOW,,,,if it's going to be your shop just put in a wood floor, rib the joists board and glue them down to the slab then put down the sub floor....
Joke a Day bobj3 Lobby 389 09-01-2008 04:53 PM
Garage Door Joinery jimcrockett Table-mounted Routing 10 08-10-2008 10:31 PM
Floor Polishing Machine rocky.disalva Tools and Woodworking 1 07-06-2008 10:19 AM
Garage doors mailee Show N' Tell 5 06-05-2007 09:27 PM
Identify Stanley level? Anniedog Tools and Woodworking 3 06-06-2006 01:04 PM
