Rate This Thread - Dadoes with table saw.
Thread Tools Display Modes
Old 07-18-2007, 05:26 PM   #1
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Default Dadoes with table saw
Was doing some work yesterday and needed to make a frame with half-lap joints on the corner. Decided to use the table saw and a stacked dadoe set. Well, I'm glad I planned on putting screws thru the boards because there was no way the half-laps were smooth enough for a strictly glue joint. The frame was for the bottom of the aforementioned tblsaw so pretty wasn't needed as it's just to mount casters to. I'd hate to use this for a good joint... by the time I got done with a chisel to smooth the surface, the joint would have been way off.
I was under the impression that a stacked dadoe set was the way to go to provide a clean, smooth bottom on the dadoe. Do I just have a messed up set of blades, or was I given the wrong information? I also have a wobbler style dadoe blade, but didn't use it because I was told it left an uneven cut.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 07-18-2007, 07:30 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Brian
Many of the low cost/low end dadoe saw blade sets will do that BUT you can use a trick I use now and then , once you have the lap joint done move the stock from side to side over the blades BUT with care, this will clean up the cut so you can use it for a glue up joint....but you need to under cut the joint by a 1/32" or so ...this will give you some stock to clean up on the last pass sideways...
Most of the lap joints are hard to make or to say hide any errors once your done with them they are wide open for view so to speak...
bobj3 is online now   Top - Reply with Quote
Old 07-18-2007, 08:24 PM   #3
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Originally Posted by bobj3
. . .once you have the lap joint done move the stock from side to side over the blades . . .
Ditto Bob's suggestion.
I've never tried a dado blade on my little benchtop saw --
so when I do laps on it -- I make several individual passes - then set my rip fence for a stop and use that same side to side technique -- a little careful sanding and you are have a nice smooth joint.
Strictly as a matter of personal preference -- I prefer routing to using a table saw - because I can see the cut being made.
But it usually comes down to my mood -
Drugstore Cowboy is offline   Top - Reply with Quote
Old 07-18-2007, 09:20 PM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Routing for half laps every time. A simple one time jig can be made in next to no time or a permanent one in an hour or two.
Harry
harrysin is offline   Top - Reply with Quote
Old 07-18-2007, 10:02 PM   #5
BrianS
Forum Geek
BrianS's Avatar
This would have been my choice as well, but my current router/table setup consists of a 1/4" shank Craftsman. It works very well, and I've cut several dadoes with it, but in MDF, not real wood. These were just spruce 2x4's, but still harder then MDF. I've got a better one now, just have to cobble the table together and get it mounted.
Do you have any pics of the half lap jig? The permanent one sounds like the good one to me. Might as well invest a bit more time in it but only have to make it once.
Brian
Old 07-18-2007, 10:07 PM   #6
BrianS
Forum Geek
BrianS's Avatar
Hi Brian
Many of the lost cost/low end dadoe saw blade sets will do that BUT you can use a trick I use now and then , once you have the lap joint done move the stock from side to side over the blades BUT with care, this will clean up the cut so you can use it for a glue uip joint....but need to under cut the joint by a 1/32" or so ...this will give you some stock to clean up with the last pass sideways...
Interesting idea, will keep that in mind if I use the tblsaw for this again. The dadoe set is a Delta one, and it wasn't cheap. Well, it WAS cheap to me, a friend was moving and filled up my van one day with stuff he didn't want to move. It's not seen much use judjing by the sharpness of it, but maybe that's the reason he didn't want to move it.
Brian
Old 07-18-2007, 11:59 PM   #7
Senior Moderator
Supreme Forum King
Mike has disabled reputation
If you are simply making half lap joints and want a clean surface then do a cheek cut(standing the board on end) at the proper depth and then a shoulder cut to trim off the waste. Quick and clean.
Old 07-19-2007, 12:25 AM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Just one more easy and quick way to make lap joints, see below
dadoes-table-saw-one-more-way.jpg  dadoes-table-saw-one-more-way-.jpg  dadoes-table-saw-one-more-way-b.jpg
Old 07-19-2007, 06:21 AM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Brian
Brian, because I haven't done a half lap for years I don't have a permanent jig, there are lots about, this one is in the Time Life "Shop Made Jigs and Fixtures"
I hope it comes through clear enough to follow and that the copyright cops don't knock on my door.
Harry
Old 07-19-2007, 08:40 AM   #10
BrianS
Forum Geek
BrianS's Avatar
My original plan, and I even spent some time making a tenoning type jig to slide across my rip fence... of course, that was BEFORE I realized that it's extremely difficult, impossible in fact, to make a 3.5" deep cut with an 8" sawblade. Just doesn't work. Oh well, the jig is made... I'll use it for something else eventually.
Brian
Looking for input on home built router table italian biker Table-mounted Routing 1 05-29-2008 07:07 AM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 11 07-25-2007 02:45 PM
Cubbie's Router Table Cubbie Table-mounted Routing 4 03-19-2005 03:13 PM
