| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Jr. Member | What kind of wood is the best to work with for a beginning sign maker? I need to figure out what wood I can use that isn't gonna give a bunch of grief & is pretty commonly available @ a local Lowe's or Home Depot. I will be using a template for recessed routing on boards approx 5' long. Thanx! |
| | #2 |
| Senior Moderator Supreme Forum King | As a rule pine will be the cheapest, but the best choice would be cedar. Fewer knots, a soft wood that routs easily, still low in cost. It doesn't get much better than that.
| | #3 |
| Registered User Jr. Member | Thanx for the suggestionon the type of wood. Also ~~ when i route recessed letters what is a good way to sand & smooth the recess. I have tried it manually w/ sandpaper but that will take forever. There has to be a better way - different bit? any tool for smoothing out the recess? Any suggestions? thanx |
| | #4 |
| Senior Moderator Supreme Forum King | I am guessing you are making free hand letters and not using a lettering jig? Your best bet would be to do your clean out with a dish cutting bit if possible. They make these in a 5/8" diameter and they will provide a clean level surface.
| | #5 |
| Registered User Jr. Member | thanx for the response Mike. I am using a lettering jig to do recessed letter and seem to get some "burring" when going against the grain. I have found it very time consuming to try to smooth these out by hand with sandpaper. any suggestions? |
| wood residential and business sign routing with | mark disaverio | Introductions | 4 | 04-06-2008 11:31 PM |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 10:29 PM |
| Guidance for making wood signs | rvguy | Introductions | 3 | 10-10-2007 09:56 AM |
| Router bit burning the wood!!! | rovailla | General Routing | 7 | 07-18-2007 03:15 AM |
| Questions about wood Pallets and moisture | GoonMan | Tools and Woodworking | 2 | 07-05-2005 08:11 PM |
