Rate This Thread - Deep collars on guide bushings..
Thread Tools Display Modes
Old 12-10-2004, 08:31 PM   #11
hcbph
Dedicated Member
hcbph is on a distinguished road
If you're looking for a PC style set that extend below the router about 1/4", check out the Shopfox set sold by Grizzly. They're shorter than my other set (Freud), also PC style.
I like the deeper ones when I'm using them with edging while the shorter ones while using patterns.
hcbph is offline   Top - Reply with Quote
Old 12-10-2004, 11:02 PM   #12
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Everybody on the planet uses the Porter Cable style bushings. Everybody except Craftsman, Skil and Bosch. This is because Bosch decided it was easier to have a simple twist lock design instead of the threaded collar design. I have to tell you its nice to slide the lever less than a quarter turn to change bushings, much faster change over. Of course I have an adapter to use Porter Cable style in my quick change set. Talk about covering the bases!
Old 12-12-2004, 03:57 PM   #13
hcbph
Dedicated Member
Like aniceone2hold, I have a Bosch plunge router and because I had 2 other sets of PC collars, I bought the PC collar adapter. Only thing I had to do was do a little cleanup on it because the collars didn't seat fully. Having done that, it works perfect. When not available I made my own adapters to use the same collars on all my routers.
Freud FT1700 Router and Guide Bushings dwwilson44 Guide Bushings and Templates 7 08-21-2008 08:49 PM
Guide bushings for skil 1825 rick112563 Guide Bushings and Templates 1 05-05-2008 09:19 AM
need something to use guide bushings on! Help Please!! unlimitedwoodworker Guide Bushings and Templates 8 11-15-2007 03:42 PM
Guide bushings on the cheap routerman1969 Guide Bushings and Templates 14 07-01-2007 09:25 AM
Guide bushings saltysteele Tools and Woodworking 0 04-22-2005 03:37 PM
