| | #1 |
| Registered User Forum Geek | I just purchased a 9 piece Porter Cable guide bushing set. Most of the collars seem excessively deep, is there a 'recommended' method of cutting them down to work primarily with 1/4" templates? Or just go after them on a grinder until they are short enough to work on the thin pattern stock? It would also be nice to learn the reason for the deeper collars -- might be I need to buy another set to have both collar depths? |
| | #2 |
| Registered User Forum Fanatic | I haven't figured out the reason for the deep collars either. Being able to turn the ends down in a lathe would be perfect. Lacking that careful grinding would be acceptable. The actual depth of the collar really needs to be just a bit less than a quarter of an inch for use with quarter inch plywood template material. |
| | #3 | |
Now go and look at: http://www.routerforums.com/showpost...28&postcount=4 I took a picture of the PC set and the "brass" set. I think I have done several other posts on this subject so you might do a search or look through all my posts.... well maybe that is a bit to big a task..... just use the search. Also I remember seeing a post about some one (maybe Woodcrafters) having the brass set on sale???????? Ed | |
| | #4 |
| Registered User Forum Geek | Well, this is what I have -- so I'll guess I'll have to spend some quality 'grinding time' in the shed. |
| | #5 | |
BTW the PC bushings are a plated steel so where you grind it can rust so keep that in mind and put some finish on that edge. Ed | |
| | #6 | |
| Registered User Forum Geek | Quote:
| | #7 |
| Senior Moderator Supreme Forum King | Ed, the guide bushing sale ended Nov 30th. Good sale items that are current include: Woodcraft has the Whiteside 3/16" radius pointed round over bit for $16.49(Month of Dec), Rockler has their 1/2 blind dovetail jig for $49, the router table switch for $14.99, Rockler router bits buy one and get one of equal or lesser value for half price.(Good only Dec 11 & 12 at the retail stores) Rockler also has their 48" aluminum bar clamp regular $24.99 for $16.99 (Limit 2, good only Dec 18 & 19 at the retail stores) Sign up for the monthly newsletters from Rockler and Woodcraft to stay on top of these values. Mike |
| | #8 |
| Registered User Forum Fanatic | Reible.. I have never used router bushings,And I want to know what set to buy,They don't tell you the overall size they only tell you the small hole size. They all say it is for Porter Cable. .Well I have a dewalt 621 2hp.It has a two step hole in the center the small one is 1 3/16 and the larger hole is 1 3/8 .So I would really like to get a set but I don't know what to buy . Grizzly has a set for $24.95. But like I say, I am completly in the dark about it. O.K. Learning Herb, I try to learn some thing new every day...
__________________ I try to learn some thing new each and every day ,Learning Herb
| | #9 | |
Also look at the barrel length, it should be short of 1/4" (.250) something like .234 or so. All the barrels should be this length! The sets normal have 7 sizes and one ring nut. I would shop around for a "deal" as I have seen prices as high as $40 plus shipping and handling! The sales are hot and heavy so maybe some kind person will post a sale somewhere, please????? The $25 might be the best you can do now a days...... Ed | |
| | #10 |
| Registered User Forum Fanatic | Ed. Thanks much, so what you say is most of all the bushings sizes are the same 1 3/8". Yea I would really like to start using them it would open a big new world for me ,With all the jigs that one can make.Thanks again,, Learning Herb ( I try to learn some thing new every day..)
| Freud FT1700 Router and Guide Bushings | dwwilson44 | Guide Bushings and Templates | 7 | 08-21-2008 08:49 PM |
| Guide bushings for skil 1825 | rick112563 | Guide Bushings and Templates | 1 | 05-05-2008 09:19 AM |
| need something to use guide bushings on! Help Please!! | unlimitedwoodworker | Guide Bushings and Templates | 8 | 11-15-2007 03:42 PM |
| Guide bushings on the cheap | routerman1969 | Guide Bushings and Templates | 14 | 07-01-2007 09:25 AM |
| Guide bushings | saltysteele | Tools and Woodworking | 0 | 04-22-2005 03:37 PM |
