Rate This Thread - Faux Cabinet Doors.
Thread Tools Display Modes
Old 08-03-2007, 01:51 PM   #1
WoodyRon
New Member
WoodyRon is on a distinguished road
Default Faux Cabinet Doors
I'm building an oak buffet with two doors. I don't have a router bit set for raised panels so I thought that "maybe' I could route a design in an oak board, cut it to size, rabbet the back, and round over the edges to use as a door. Any thoughts on this process and any thoughts of what type of bit to use? Basically I just want a simple line design following the profile of the door. Thanks!
WoodyRon is offline   Top - Reply with Quote
Old 08-03-2007, 02:16 PM   #2
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
Ive done that several times.
In fact one of my first major projects was a set of wall units w/desks.
I did exactly what you described - except I was using pine at the customers request.
That was about 20 years ago -- and they never complained ---
As for process --
I was working out of my father-in-law's garage so I had to keep it pretty simple and work with what was ready at hand --
Basicly I fastened the board down with brads
then sketched out where I wanted the groove
then set my rounter down at various points with the tip of my v-groove bit on the line
tacked down edge guides on each side touching my router base (this gave me correct position without a lot of measuring)
set the depth for my groove
and followed my guides.
yes -- I COULD have made a template and used a bushing
But - I didnt have a bushing - and I did have scrap wood for a frame.
The only DOWN side I can see to doing doors this way is:
-- your grain crosses over your grooves - and there is end grain showing at the top of the doors- so anyone with with a good eye and a picky nature will see immediately they are not 'true' rail and stile doors
Fortunately - the times I have done it -- this was not an issue to the customer.
If it's not for you either -- my .02 is what you are suggesting should work fine.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 08-03-2007, 06:56 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Cove or corebox bit would work well here Ron. As well as any bit designed to plunge and make a profile.
corey
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Kitchen cabinet make over (new doors / drawers) Nickbee Show N' Tell 3 05-22-2008 07:35 PM
Oak draw fronts and cabinet doors vapochilled Show N' Tell 12 01-17-2008 01:06 PM
arched rail cabinet doors jimf Introductions 1 02-12-2006 11:41 AM
kitchen cabinet doors help puretrick Tools and Woodworking 15 06-05-2005 04:28 PM
Cabinet doors Jens Jensen Table-mounted Routing 12 11-09-2004 09:02 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
