Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 12-14-2004, 10:58 AM   #1
dustmaster
Dedicated Member
dustmaster's Avatar
dustmaster is on a distinguished road
Default Dull router bits
What is the best way to know when your router bit is too dull to use? I noticed today's tip was not to use dull router bits, but as a newbe to routing, I do not know how to confidently tell when the bit is ready to be tossed.
dustmaster is offline   Top - Reply with Quote
Old 12-14-2004, 04:41 PM   #2
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Visual inspection is the best way. Dull router bits are shiny in spots along the profile cutting edge. You can see this by looking at the cutting edge as you move the bit around in the light, dull will give a reflection off the cutting edge. For the first time you might want to use a magnifying glass to take a closer look at the cutting edge. When the router bit is sharp, you won’t be able to see the reflection on the cutting edge.
If dull, they are harder to push through your material so if you are using a bit that seems a little hard to push the material through it, check it. Most of the cheaper router bits can be disposable but your more expensive router bits can be re-sharpened at a local carbide sharpening specialist.
If the router bit has a bearing, it is also a good idea to rotate the bearing between your fingers to feel it before you mount in the router. If its rough feeling it needs to be changed, if its moving smoothly then use it.
My thoughts on dull router bits,
Rick and Bob
The Router Guys
Already Problems neuschu Introductions 7 01-22-2008 11:32 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
