Rate This Thread - Help with a Delta planer.
Thread Tools Display Modes
Old 12-16-2004, 09:19 AM   #1
boxer
Supreme Forum King
boxer's Avatar
boxer is on a distinguished road
Question Help with a Delta planer
I had the hardwood store I buy my exotics from to mill some lumber for me. They did a really terrible job planing. I get a pretty good discount on my lumber, and they don't charge me for the milling, so I don't want to mess things up by complaining. But, a few of the boards they planed taper off to one end & one edge. I was wondering what I would have to do to straighten these boards out on my delta planer. Any advice would be helpful.
Thanks,
Kevin
boxer is offline   Top - Reply with Quote
Old 12-26-2004, 10:01 PM   #2
x372sailor
Dedicated Member
x372sailor's Avatar
x372sailor is on a distinguished road
On your planer you need a flat "reference edge" which the planer base will follow. The upper, planed surface will end up parallel to the reference edge.
Of course you should break down your boards into slightly oversized blanks for the parts you require. In this case you will maximize the available stock. So if you need 2" rails, don't start jointing/planing 6" wide and full-length boards.
x372sailor is offline   Top - Reply with Quote
Old 10-08-2006, 09:43 PM   #3
silvercreek
Jr. Member
silvercreek is on a distinguished road
you can build a sled with a flat board underneath the warped board just make it about 6 inches longer and glue or screw board at each end of the flat board thinner than what your trying to plane the warped board . It works like a sled.
silvercreek is offline   Top - Reply with Quote
planer decision... reikimaster Tools and Woodworking 9 10-08-2007 11:27 AM
Jointer? Or Planer? Which one first? reikimaster Tools and Woodworking 26 09-27-2007 01:38 PM
used planer reikimaster Tools and Woodworking 16 09-09-2007 09:03 PM
Delta DC-33 Planer Manuals mshaf23783 Tools and Woodworking 1 06-30-2007 04:19 PM
