| | #1 |
| Registered User Forum Fanatic | Hay Reible,, How does one put a photo with his name on the post, Thank you much Learning Herb ![]()
__________________ I try to learn some thing new each and every day ,Learning Herb
| | #2 |
| Registered User Dedicated Member | It's the "Avitar". Under User Profile you can download or choose from existing. Only limit is it cannot be bigger than 80X80 pixels. |
| | #3 | |
I'm not sure what you are asking..... Do you want to add a photo in with the text or as an attachment or just post it in the "Gallery" and reference it here??? (Anyway maybe on of the kind "watchers" could move this thread to the "Off Topic Discussion" area and I will try and answer it after Herb gives me a bit more information.) Ed | |
| | #4 |
| Registered User Forum Fanatic | Yes Ed. I want to kinow how you put the little photo under your name when you post a note,every body has those little photos.yours looks like a star. And to make this post fit in the tool forum.I say this did you see the new slot cutter router bit ,You can turn a knob and make the cut thicker or thinner.Thay have twt sizes ,One that goes up to 1/4 in. and one that goes up to 1/2 in. Thay are really neet. Learning Herb
| | #5 |
| Registered User Supreme Forum King | OK then, yes that is the Avatar. To do this you click on the "User CP" along the top bar (far left). This take you to another page where you then look for "Edit Avatar" and click that. As was mentioned it is limited in size so if you want it do your own you might have to shrink the image to fit. Mark has a large collection and taking one of those is fine too. I end up changing mine every little while and must have used maybe 20 different ones already since Sept. So what I'm saying is you can change this when ever you want and can use your own. It should be somewhat clear once you get to the page but if you need help let me know I can do a step by step for you. Also if you don't have software to reduce the image you want to use message me and I'll help with that as well. Ed |
| | #6 | |
http://www.routerforums.com/general-routing/303-has-anyone-used-ezdial-slot-cutter.html Ed | |
| | #7 |
| Registered User Forum Fanatic | Yes , thats it .looks great. but what do you think. Sometimes looks are deciving. Learning Herb
| For Harry - A Carving Photo Journal | challagan | Corey's Wooden Stuff | 21 | 05-18-2008 10:39 AM |
| panel doors actual photo of different profiles | sammy57 | Router Bits - Types and Usage | 4 | 03-11-2008 05:15 PM |
| My router haven photo tour | Bob | Show N' Tell | 31 | 06-23-2007 05:56 PM |
| photo test (first router table) | jack52 | Table-mounted Routing | 4 | 02-09-2006 08:06 PM |
| Members' photo gallery | g-man | Lobby | 7 | 12-09-2004 09:05 PM |
