| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Forum Contributer Supreme Forum King | Here's a neat little trick, neat way to to put in the corner radius... ======== Finding a Corner Radius I often need to make a rounded corner on a workpiece. But this can often lead to a lot of trial and error until I get the corner radius just right. You’ll find a carpenter’s square and a compass makes this task quick and easy. And the results are perfect every time. For example, I needed a 4″ radius at the corner. So I lined up the edge and end of the workpiece with the 4″ mark on the outside of both legs of the square (see photo below). Then I marked the point of the square. Finally, put the pointed arm of the compass on this mark, extend the compass to the edge of the workpiece, and scribe the line, as shown in the photo. Good Woodworking, Phil Huber Online Editor, ShopNotes © August Home Publishing Company 2200 Grand Avenue, Des Moines, Iowa 50312 ==============
| | #2 |
| Registered User Supreme Forum King | Oh now thats cheatin!! lolExcellent tip though. Thx Bj. Btw, I do subscribe to both shopnotes and woodsmith mags. I absolutely drool when I get them. ![]()
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #3 | |
| Registered User Forum Geek | Quote:
I make note of the diameter of common household items. A quarter is 1" (1/2" radius), the lid to my plastic water bottle is 2", the lid to my travel mug is 4" (2" radius) etc etc ---- When I am real lazy -- I just scoot the desired item into the corner and trace the edge. But yes - I agree that's a great and quick way to find a desired center point. And certainly more versatile. Last edited by Drugstore Cowboy; 09-27-2007 at 07:34 PM. | |
| | #4 |
| Registered User Member | I seen the same email just a minute ago. Neet little trick. Dave |
| | #5 |
| Retired Moderator Supreme Forum King | Excellent Tip BJ, thanks! Corey
| | #6 | |
| Forum Contributer Supreme Forum King | Thanks Corey Many may get the same email as I did But some may not and when I see a neat one I will pass it on , just like this one.. ![]() It sure beats using a paint can ![]() http://www.routerforums.com/36229-post4.html ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-28-2007 at 11:52 AM. | |
| | #7 |
| Forum Contributer Supreme Forum King | When I see things like that Bj. I can't help thinking "now why didn't I think of that" Thanks for passing it on.
__________________ Harry |
| | #8 | |
Not if the paint can (or other item) is handy and happens to have the exact radius you are looking for.But yes - for the 90%+ of the time when they don't -- a square and a compass is an excellent way to go. A common variation of that idea -- if you don't have a compass handy or if you need a radius larger than your compass allows for - is to put a thumbtack at your center point and use a piece of string tied to the point of your pencil. | |
| | #9 |
| Registered User Forum Geek | Hi BJ Well, nice trick he has but, framing square is too big (for me) and must be supported for accurate marking (as you can see on the picture...) I do it a little bit different and get the same result by pre-setting the stop on the ruler, line from one side, line from the other side, stick the compass in the intersection and go. Just for the photo, I used 2 rulers but actually, I'm using only one. Best Regards niki ![]() |
| | #10 |
| Forum Contributer Supreme Forum King | Hi niki Like you I'm not to crazzzzzy about using the framing square I now use the Incra Rules, they are Dead ON... As you know the size of the pencil lead can put it off just a bit but with Incra rules, they took that error out of it.. http://www.amazon.com/Incra-IRSET18-...9030777&sr=1-7 [quote=simplenik]Hi BJ Well, nice trick he has but, framing square is too big (for me) and must be supported for accurate marking (as you can see on the picture...) I do it a little bit different and get the same result by pre-setting the stop on the ruler, line from one side, line from the other side, stick the compass in the intersection and go. Just for the photo, I used 2 rulers but actually, I'm using only one. Best Regards niki
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 09-29-2007 at 12:41 AM. |
| Determining a radius cut | RoyBullets | Jigs and Fixtures | 7 | 06-23-2008 09:10 AM |
| Working with radius | MiamiSnookII | Starting Off | 5 | 01-07-2006 11:20 AM |
| 3/4" Radius roundover bit with 1/4" shank | chrisogrady | General Routing | 8 | 04-01-2005 09:08 PM |
| Corner dovetails | trap | Tools and Woodworking | 2 | 02-17-2005 07:00 AM |
| Help on Inside Corner Routing | aquarium-builder | General Routing | 6 | 01-06-2005 03:43 PM |
