Rate This Thread - Hitachi M12V Router Problem.
Thread Tools Display Modes
Old 12-27-2004, 04:55 PM   #1
dcarriere
dcarriere is on a distinguished road
Default Hitachi M12V Router Problem
I just recently bought a Hitachi M12v Router to go in my Router Workshop table. The bits (happened with a spiral and a rabbet bit) have a tendency to pop out of the collet when using a 1/4 inch collet. I don't have that problem when using the 1/2 collet. All of the slits are aligned on both the 1/4 inch insert collet and the 1/2 collet. I contacted Hitachi and they sent me another collet set. I still have the same problem.
I was wondering if there were anyone else with the same problem and if was possible to solve it.
dcarriere is offline   Top - Reply with Quote
Old 12-27-2004, 06:02 PM   #2
x372sailor
Dedicated Member
x372sailor's Avatar
x372sailor is on a distinguished road
My Hitachi is a few years old so maybe this is a new problem. I have never experienced it. (I usually use 1/2" shank bits but I do have a few 1/4" shafts. When you insert the bits are they a good friction fit in the 1/4" collet, and similarly is the 1/4" collet a reasonable friction fit in the 1/2" collet? Mine are both.
I am always careful to align the slots and insert bits the full length of the 1/4" collet and the 1/4" collet is fully buried in the 1/2" collet.
x372sailor is offline   Top - Reply with Quote
Old 12-28-2004, 12:42 AM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
One important tip: be sure your bits are clean, rust & oil free before inserting them. Check to see if the bit is bottoming out inside the collet. If you insert the bit fully till it stops, then back it off 1/8" you should get a tight fit. Remember as the nut is tightened the collet is pulled into the shaft opening. This can cause the bit to bottom and not give a good grip. Somebody suggested inserting a small O-ring the same diameter as your bit into the collet before installing the bit. This allows the collet to tighten while eliminating the bit bottoming out. I dont know if its the same on the Hitachi as it is on the Bosch, but some collets require that you insert them into the nut with a sort of twisting action to seat them fully before attaching the nut to the sleeve. Another possibility is a burr or chip inside the nut. If your mating surfaces are clean and none of this helps contact a repair facility for assistance. DO NOT USE A ROUTER WITH LOOSE BITS! THIS IS VERY DANGEROUS!
Old 12-28-2004, 06:50 AM   #4
template tom
Forum King
Check your cutters 1/4" or 6mm That is the trap you may fall into
Tom
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
Hitachi M12V & Router Plate/Lifts Cubbie Table-mounted Routing 3 09-22-2006 12:53 AM
Problem with my Hitachi M12V Visteonguy Table-mounted Routing 23 08-18-2005 11:22 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
