| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #31 | |
| Forum Contributer Supreme Forum King | Hi Corey " properly tensioned? " = yes,, I just came in from the shop but I will take a snapshot of it on Sat. it's a smiple block of wood, that's lets me sit it on the knob and the frame .... At one time I marked the rod that came out of the knob but it would be lost over time....so I made a stick to do the same thing and I just hang it on the back side of the band saw.. ============== Quote:
| | #32 | |
| Retired Moderator Supreme Forum King | Quote:
![]() Corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #33 |
| Retired Moderator Supreme Forum King | I found this info while searching another site. Most have heard of Lonnie Bird. He uses a guage for tension but since that costs 300.00 he says use the 1/4 flex test...just as Doug Hicks advises in the Woodsmith videos. http://www.taunton.com/finewoodworking/pages/w00013.asp Here is one from Timberwolf using the flutter method.. This sounds like the method Reikimaster uses. Bandsaw Tune Up Link: http://www.woodcraft.com/articles.aspx?articleid=223 another: http://www.americanfurnituredsgn.com...20Dec%2003.htm Corey
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ Last edited by challagan; 10-19-2007 at 11:21 PM. |
| | #34 | |
| Forum Contributer Supreme Forum King | Hi Corey Here's some snapshots of the adjusting/adjustment block easy one to make and will save hours of setup time on the band saw...once you have it set....for the right adjustment ,this block will do both adjustments. ====================== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-20-2007 at 02:11 PM. | |
| | #35 | |
| Banned Supreme Forum King | Quote:
Bob, Is that block of wood just to keep track of your Tension / non Tension settings? If so, I do it very easily on my G0555... Once I get it tensioned, I merely push a lever up to detension the blade... and pull it back down to get it tensioned & ready to cut. Works like a charm! My band saw is right up there in "favorites" along with the router. | |
| | #36 |
| Retired Moderator Supreme Forum King | I got yah Bj, a go-no-go gauge. Thanks for taking the pics. Joe, not all band saws have a detensioning lever. Corey
| | #37 | |
I realize that... I merely mentioned it for the people "considering" a band saw... it can be a piece of cake. ![]() | |
| | #38 |
| Forum Moderator Supreme Forum King | Bj, Now that is a cool idea if there ever was one. You are forever coming up with the best jigs and fixes to make life easy in the shop and save money to boot. Looks like I'm going to have to save this one in my reference file beside the many others I have from you With winter coming these will make great small projects on those dreary days.
__________________ Cheers, Bob |
| | #39 |
| Registered User Forum Fanatic | Who knew I'd open such a can of worms ![]() Great advice all, and clearly much of it needed to be said, judging by the thread length. Looking at mine and DCs saw, we have very similar saws, I have now put on a 3/8" blade. Rigged up a brush on the lower roller. and through trial and error, found the correct tension to apply for a straight cut. Despite costing me less than a good night out, it cuts very well with the bigger blade. I can see it being used far more than I had imagined. |
| | #40 | |
Very good!! I have found that I look to the band saw quite often... my choice over the TS most of the time. I'm sure you will like it too. | |
