Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 10-14-2007, 07:19 PM   #1
Roefa
Forum Fanatic
Roefa's Avatar
Roefa is on a distinguished road
Send a message via Yahoo to Roefa
Question Blistering Hot Bearing
Hi Folks -
After running with no load for 15 - 20 SECONDS!, my brand new router gets
so hot at the collet-end bearing you can't touch it. The manufacturer's customer service department tells me that this is normal and is no problem.
I just can't accept that. I have had four other routers (all stolen or given away) and I don't recall that they got very hot. Does anyone here know for sure whether or not this should be considered a problem?
Your thoughts would be greatly appreciated.
Roefa
Roefa is offline   Top - Reply with Quote
Old 10-14-2007, 07:33 PM   #2
vapochilled
Forum Fanatic
vapochilled is on a distinguished road
I'd say problem for sure!
vapochilled is offline   Top - Reply with Quote
Old 10-14-2007, 11:04 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
After just 15 - 20 seconds... that sounds like a problem to me.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 10-14-2007, 11:57 PM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Most definitely a PROBLEM, return it without delay for replacement/refund, you're choice.
Harry
harrysin is online now   Top - Reply with Quote
Old 10-15-2007, 11:41 AM   #5
Noddy
Forum Fanatic
Noddy's Avatar
Noddy is on a distinguished road
Something is wrong.
If the MFG says that is normal a) their full of *____, b) your response to them should be "then they all need to be fixed, and you can start by fixing mine".
This is unless of course you are talking about Harbour Freight (or the like) being the MFG.
If you have something like PC, Hitachi, Bosch, Dewalt, Makita, etc. then something is wrong, and I (personally) wouldn't use it.
The shaft is spinning at 20,000 RPM. That bearing is either crushed, or within a tolerance that isn't right. Hence the heat build up. Keep running it, and something will break.
Regards-
Noddy
Noddy is offline   Top - Reply with Quote
New Guy with Bearing Bit question FREUD nicksorenson Router Bits - Types and Usage 13 06-05-2008 05:48 PM
Top bearing sliding up shaft MisterHeavy Router Bits - Types and Usage 3 04-28-2008 03:02 AM
Is my bit dull? tpyke Router Bits - Types and Usage 5 03-23-2008 10:24 AM
Removing bearing? Drugstore Cowboy Router Bits - Types and Usage 3 06-23-2007 04:05 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 2 10-22-2005 07:41 AM
