| | #1 |
| Registered User Forum Geek | Ok, you guys have helped me out a ton already and I'm back for more! ![]() I don't have a sander. I currently do all sanding by hand. I'm getting old, have a lot of nerve and muscle damage in my neck and shoulder, and sanding really takes a heavy toll on me. So I am looking for a sander. My current thinking is that I should be looking at a variable speed random orbital, but I am wondering if I should get one of those AND a 1/4 sheet finishing sander. Then it comes down to which one? I have looked at tons of them over the last few days and gone in search of reviews. Not a single one that I looked at had all positive reviews. And they each seemed to have the same proportion of negative ones. For a random orbital (not pneumatic... electric) I am looking in the $70-$90 range. If I end up getting a 1/4 sheet sander those are all over the place and it looks like there are some decent ones as low as $40. So I come here, to the folks I trust, and say, "What do y'all have?" What do you use, what do you like, what do you think you'd get NOW if you were getting a sander? Thanks |
| | #2 |
| Retired Moderator Supreme Forum King | I think you got the right idea. I use a pad sander on small items such as boxes etc. I also have several random orbit sanders ( just ended up that way) and I like my dewalt the best but I also have a pc. I like both to have dust collection on them. My little black and decker pad sander with the dust chute is great, I just wish I had a half sheet pad sander. Corey
| | #3 |
| Forum Moderator Supreme Forum King | Like Corey, I like my Dewalt ROS the best. It does a great job and I have been happy with it after 3 years of use. For the 1/4 sheet pad sander, I picked up aRyobi at the borg and it seems to do a good job for the small $ I invested in it. And yes...... a 1/2 sheet sander would really get my blood flowing ![]() BTW.... do you have a benchtop belt sander? I find mine very useful with 220 grit sandpaper on many applications.
__________________ Cheers, Bob Pictures from the shop http://s107.photobucket.com/albums/m292/bnoles616/ Last edited by Bob; 10-19-2007 at 09:09 AM. |
| | #4 | |
| Registered User Forum Geek | Quote:
By the time it died - I had a belt sander and a quarter sheet pad --- so I never got around to replacing it. Y'all make me think maybe I should. ![]()
__________________ The one who says it can't be done -- Should avoid interrupting the person doing it. | |
| | #5 |
| Registered User Dedicated Member | Reikimaster - I have and still use a PC Speedblock 1/4 sheet pad sander. It is just over 15 yeays old and going strong. I've replaced the pad twice but other than that it is flawless. Seems a little heavy at first but that seems to help you resist the urge to 'honk' down on the machine and let the sander do the work.
__________________ There are no mistakes . . .only design changes!
| | #6 |
| Registered User Forum Geek | I've got a PC 1/4 sheet, a 3x18 belt sander, and the latest purchase was a variable speed orbital sander. The orbital sander is fast becoming my favourite. The only complaint I have is that I can't hook up my shop vac or dust collector to it. It's a Mastercraft, which is a Canadian brand, and I didn't think it thru far enough to realize that it doesn't have the standard round connector on it for a vacuum.
__________________ A married man should forget his mistakes. There's no use in two people remembering the same thing! |
| | #7 | |
| Retired Moderator Supreme Forum King | Quote:
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ | |
| | #8 |
| Registered User Forum Geek | Ok.... so starting out now I have purchased the Dewalt 5" variable speed ROS. I haven't picked up a pad sander as I want to see how the ROS does. My thought was that with finer grits and lower speeds I might get a decent surface. I tested this out on a piece of rough 4x4 that I had. I used 80 grit and then 120. Holy cow! Haven't hit it with 220 grit yet and it's awesome already. I didn't try the 50 grit that I have and I probably won't hit it with the super fine pad, but man this is cool as heck. I should have done this a long time ago. Would have saved me a ton on deep-heat rub for the sore muscles after sanding by hand for long periods of time. This thing does in a couple minutes what took me hours by hand. |
| | #9 |
| Registered User Supreme Forum King | IMHO I don't think one can go wrong with a ROS. I believe they are way better than the 1/4 sheet sanders. But, I guess this also all depends upon the job too. I currently own a Makita ROS, Sears 1/4 sander and a Makita belt sander. I use the belt sander for the "rougher" jobs, then use the ROS for the finer sandings.
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #10 |
| Forum Contributer Supreme Forum King | It really does depend on the type of projects that you're engaged in. These days I'm mainly into boxes and clocks. The one sander that I wouldn't like to be without is the disc/belt sander. I also often use my Makita 1/4 sheet ROS which has an attached dust bag. My various detail sanders get very little use.
__________________ Harry |
| DC Question | angus | Lobby | 3 | 03-31-2008 07:29 PM |
| Belt Sander --- hand held or benchtop? | Drugstore Cowboy | Tools and Woodworking | 14 | 10-20-2007 01:41 PM |
| My Sander Arrived!... | challagan | Tools and Woodworking | 9 | 04-26-2007 09:50 PM |
| a member of 2 years but never posted a question. Here goes...(PC 695/bosch table) | routerron | Introductions | 4 | 09-19-2006 11:33 AM |
| Porter cable 632 vs Sander | Glenmore | Tools and Woodworking | 6 | 12-10-2004 05:51 PM |
