| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Senior Moderator Supreme Forum King | I have to build a stand for a 12" planer. I have a nice design from Shopnotes which calls for the sides to be made out of 3/4" plywood. Will the Woodstaulk material work well in this application? I know I have seen it used for box sides and such, just concerned about the vibration from the motor having an ill effect on it.
| | #2 |
| Registered User Dedicated Member | Woodstaulk to me looks like MDF. Very very fine dust it seems. The closest I've gotten to woodstalk is the piece holding the brass bars I got from Oakpark. re: The Sears Router did not come with the quick change guides like the Bosch. No matter - Brass fixed to the base with lock rings is my preference. FWIW All the best CFM |
| | #3 |
| Senior Moderator Supreme Forum King | CFM, The quick change adapter has a plate that uses any PC style bushings, just loads and unloads quicker. It also accepts the Bosch bushing plates.
| | #4 |
| Registered User Supreme Forum King | I still have to actual see the product..... I have been looking around and was told Home Depot sold it, I went and ask and got this blank look "like what is he asking for?". I posted here in hopes some in the northern IL area had some idea but so far I am clueless as to where to see or purchase it. So as far as your question I don't know but I would like to. If weight is something you are thinking about the plywood is most likely lighter and with plywood the fasteners can be a no brainer. Just a couple thoughts for you. I guess that can be a winter project, contacting them and see if they have a supplier in this area. That reminds me I need to make some plans for a stand for my planner...... That would make it so much easier to use.... Ed |
| | #5 |
| Senior Moderator Supreme Forum King | Ed, they have it here in the Detroit area at HD. It runs $15 for a 3/4x4x8. Dont trust the stock clerks to know, read the side paint markings of what looks like particle board. They were clueless here too. Shopnotes has a neat plan for the planer stand.
| | #6 | |
Ed | |
| | #7 |
| Senior Moderator Supreme Forum King | I was hoping by this time somebody would have responded who has used this product. I guess it comes down to try it and see. I will report my findings.
| | #8 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #9 |
| Senior Moderator Supreme Forum King | Thanks Rick, I will give it a try.
| | #10 | |
| Registered User Sr. Member | Quote:
__________________ I've sanded so much my fingerprints are gone! | |
| Bit for corner of plywood | rharveyva | Router Bits - Types and Usage | 5 | 03-24-2008 02:01 PM |
| Problem Rabbeting Plywood | JDługosz | Portable Routing | 25 | 01-14-2008 01:56 PM |
| Squaring plywood panels | ShaneB | Table-mounted Routing | 37 | 12-22-2006 07:40 AM |
| Dovetails In Plywood | rmaxa | Router Bits - Types and Usage | 6 | 12-19-2006 11:00 PM |
| plywood glue bit | keith | Table-mounted Routing | 4 | 03-03-2006 11:06 AM |
