| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Sr. Member | Being new to routing and collecting bits ( I think of them as baseball cards for big kids) I would appreciate if someone in the know would give a primer on raised panels (including bit selection). Please use little words, and describe like you are explaining to someone who knows nothing about raised panels. (cause I don't) Thanks CB
__________________ I've sanded so much my fingerprints are gone! |
| | #2 |
| Senior Moderator Supreme Forum King | CB, the simple version is you cut grooves in the rails and styles to accomodate a thin edge left on the panel. Think of it as a lengthwise dado in your frame, and a rabbit cut to fit into it on the panel. Some raised panels are plain and flat, others use different cut shapes for more decorative edges. A simple raised panel can be made by tilting your saw blade to 13 degrees, set your fence so it is 1/4" away from the blade, standing your panel on edge make a pass on each side. You will need a tall fence to support the panel while it is cut. This gives you a flat angled cut. If you spend a bit of time, you can adjust your blade height so it meets the edge of the panel. This will give you a small decorative lip around the center raised section. The really nice looking raised panels are cut with a panel raising bit. You can get a cove or roman ogee cutter to really spruce up your panel. Panel cutters are available in 2 styles, horizontal or vertical. When using a horizontal large diameter cutter for a larger panel you can have a bit up to 3 1/2" diameter which will require a 3+ HP router. The newer vertical panel raising bit to cut the same shape would have perhaps a 1 1/2" diameter, less HP required.(and a bunch cheaper!) Either way, dont try to make your entire depth of cut in one pass. You will be removing a lot of wood, so take it in layers.
| | #3 |
| Registered User Dedicated Member | Funny you asked. I was surfing and picked up this, thought you may like to look. It is pretty good photo's should help. http://www.oldham-usa.com/Products/B...asic_steps.htm
__________________ God created man, then woman and man said, Give me my wood shop! |
| | #4 |
| Registered User Forum Fanatic | Viper1 The link to oldham-usa, was very helpfull in understanding how raised panel doors are made. I bought a doormaker's bit set, from HarborFreight Tools. 1/2 inch c3 tipped. All three of the bits have a max. spped of 8000 rpm. I have the speed controller set as low as it will go and still not souind like the router is stopping. I have an old panel door, and I am going to take it apart to see how it is made. Tell me how to do it and I'll quit, tell me and show me and I attempt it, show me an example and I'll be able to make a door. What do I want to do after learning? Well, I would like to start out, by panelling one wall. Making the panels about 3 foot wide. By the way, pine, which I used to make a sample panel, is not good, if the bit hits a knot or a place where there is a lot of pitch, watch out! Bud
__________________ The Geezer |
| Question on raised panels | kylawyer | Table-mounted Routing | 5 | 03-08-2008 11:44 PM |
| Is there quick fix for slightly loose fitting raised panels? | tpyke | General Routing | 3 | 02-13-2008 08:59 PM |
| Minimum HP required for raised panels | traveler | Router Bits - Types and Usage | 14 | 09-23-2007 05:25 PM |
| Router for raised panels | Jtomwoods | Table-mounted Routing | 3 | 08-21-2006 01:59 PM |
| Raised Panels Quick and Easy | bobj3 | Jigs and Fixtures | 2 | 06-03-2006 01:56 PM |
