| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #21 |
| Registered User Forum Fanatic | I have the De Walt 10" radial arm saw and wouldn't be without it. I have had a few of them over the years and find them very useful. I should add that I never use them for ripping stock as I use my table saw for that. I mainly use it for cross cutting pieces to length or making dados. i agree with one of the posts that they can be a dangerous tool but used carefully they are no dangerous than any other tool in the shop. They do climb cut timber while cross cutting but the idea is not to pull the blade through so much as ease it through the stock. They will hold the timber firm to the fence and down on the table if the correct blade is used which must be a negative rake blade. If a standard positive rake blade is used on one of these machines then they are very dangerous indeed wanting to lift the timber up and off the table. I have an additon on mine which also helps that is a return spring on the arm which pulls the carriage backwards behind the fence. I am no expert on these saws but have used one for the last twenty years so have learned a thing or two about them and never had an accident with one. ![]() |
| | #22 |
| Forum Contributer Supreme Forum King | "Ripping ".... feed work to the blade along the fence-- from your left to right (never from right to left)." Not necessarily so, see photographs. Whilst Bj's RAS appears at first glance to be the same as mine, I notice the anti-kickback is on the front, that being so, is the blade still turning clockwise when facing it?
__________________ Harry |
| | #23 |
| Forum Contributer Supreme Forum King | For me I always rip stock with the motor on the back side of the table top.. And always from the Left to the right...the anti-kickback bar is always on my right,,my top is a split type, that's to say the back stop can be pulled out and moved back by 6" or so , this will let me rip stock up to 26 1/4" wide if I need to..But then if I want to rip stock to 1 1/2" wide lets say, then all I do flip the motor around and put the motor on the front side of the table and feed from the Right to the Left, this in turn always puts the anti-kickback bar on the out feed side of the blade...the blade is ways trying the lift the stock up or to say the teeth are coming up from the bottom side of the stock... Small story , my son ask if you could use the saw at home and I said sure, so we took of the saw off the base cabinet and he was off ,, he siad I will get it back in a day or two, in a day ,he said here's #%$@$# your Cappy Saw,, He said it would not cut 1/2" plywood... I said show me,,,,you got it he was ripping in the wrong way he said that's the way we do it at work...I said look at you fingers and say good by to them if you still use the saw in the wrong way....then I said don't every push the stock into the blade without using a push stick..and he said push stick what's that...and we had a long talk about how to use a RAS...now he wants is own..they can do so many jobs very well plus you can hang a router on one end to make the real hard router jobs easy...XYZ thing on the RAS...It's like putting a plunge router on your RAS....with a standard base...at one time Delta/Sears/B & D, had a jig saw that just bolt on also to make it like just a band saw in a away..sanding drums also...======= ======
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-29-2008 at 09:09 AM. |
| | #24 |
| Forum Contributer Supreme Forum King | Thanks for that Bj. Because I'm right handed, I find (found) it easier to feed from right to left, but I haven't used it for ripping for 7 or 8 years. The table saw really is better for this task. I would hate to have to make a choice between a router and RAS.
| | #25 | |
| Forum Contributer Supreme Forum King | Hi Harry I like to rip with it because I can take my hands off the stock and move around to the other side and pull it out unlike the table saw... I have two types of hold downs that work well for ripping...the yellow (Orange) wheel type, spring loaded type that only turns one way.. and the spring metal bar type (Shop Smith ) type, that hold it down..You will now see why I rip from the left to the right, using the Orange hold down wheels.. the Yellow ones will let you rip from the right to the left...but it's not the norm..so they tell me ![]() http://www.amazon.com/s/ref=nb_ss_hi...dies&x=19&y=16 http://www.amazon.com/Yellow-Board-B...1619384&sr=8-1 http://www.amazon.com/Board-Buddies-...1649223&sr=1-3 http://grizzly.com/products/searchre...oard%20Buddies But to each his own... ======= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-04-2008 at 09:08 PM. | |
| | #26 | |
| Registered User Forum Fanatic | Quote:
__________________ www.PeterSpirito.com | |
| | #27 |
| Forum Contributer Supreme Forum King | Hey Peter You don't look like the Evel Knievel type just goes to show you can't judge the book by it's cover ![]() As you know the chain saw as a nick name ( shark saw) it will eat you up in a heart beat, the same for the other items you have posted... Using the RAS backwards is like jumping out of the plane with the shoot packed by a 5 year old,it will work most of the time but it only takes one time. ![]() You have been very lucky but that's just my 2 cents...==========
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-29-2008 at 09:00 PM. |
| | #28 | |
| Forum Contributer Supreme Forum King | Quote:
The Good Lord has been looking after you Peter, may HE continue to do so.
__________________ Harry | |
| opinions on radial arm drill press please. | jer760 | Tools and Woodworking | 7 | 03-11-2008 04:50 PM |
| Radial Arm Router | cabinetman | Tools and Woodworking | 12 | 04-27-2007 11:22 PM |
| Reciprocating Saws | berry | Tools and Woodworking | 8 | 09-23-2006 09:03 AM |
| radial arm saw | KENNETH KIDWELL | Lobby | 2 | 05-09-2006 10:10 PM |
| Scroll saws | ejant | Tools and Woodworking | 0 | 11-08-2004 05:51 AM |
