Rate This Thread - Sticky Collet.
Thread Tools Display Modes
Old 01-13-2005, 06:01 PM   #1
gbnevard
New Member
gbnevard is on a distinguished road
Unhappy Sticky Collet
Can anyone suggest how to prevent my 1/2 inch collet from sticking. As a result it is very difficult to release the cutters. Help please!!
Gary
gbnevard is offline   Top - Reply with Quote
Old 01-13-2005, 06:54 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Gary, there could be several reasons why your collets are sticking. First and most common would be rust. Rust on your bits or in the collet can cause it to stick. Your bits and collets must be free of rust and/or burrs. Is there any damage to the collet or sleeve? Any deformation here can create a terrible bind or a loose fitting connection. Are you seating your bits with a small gap between the end of the bit and the bottom of the sleeve? I have heard of people inserting small O rings to prevent a bit from being too close to the bottom of the sleeve. Are you over tightening your collet? 25-30 FtLbs should be more than enough to hold your bit. Do any of these ideas help? If not give a model number for your router, and brand name. Some models have quirks. The age of your router might provide a clue as well.
Old 01-13-2005, 07:06 PM   #3
cfm
Dedicated Member
cfm is on a distinguished road
Gary
A wild guess : Is the cone installed INVERTED ?
My Craftsman had this problem and I found that I inverted the cone.
Also check out the folllowing link :\
http://www.woodworkersjournal.com/ezine/qanda.cfm
Hope this helps.
cfm
cfm is offline   Top - Reply with Quote
Old 01-13-2005, 07:07 PM   #4
reible
Supreme Forum King
reible's Avatar
Mike has given some good points.
Now it is also possible that you have an older style router where the bit does not come loose when the nut feels loose, you still need to turn it past a "tight spot". Give that a try.
Then a good cleaning and inspection should be done anyway as Mike pointed out.
Let us know how things are working maybe we can come up with more things to do/try.
Good Luck!
Ed
Old 01-21-2005, 05:46 PM   #5
gbnevard
New Member
Router in new and none of the suggestion have worked yet.
Old 01-21-2005, 06:38 PM   #6
reible
Supreme Forum King
reible's Avatar
It looks like we might need more information. What make/model of router? Can you post of picture of the nut and collet? If you can post a picture how about a second one with the collet out of the router?
Do you have anyone near by who uses routers who could take a look at it?
Try and give us somemore details....
Ed
Old 01-28-2005, 05:37 PM   #7
hcbph
Dedicated Member
hcbph is on a distinguished road
One thing not mentioned is the type of connection method exists. I've got a Craftsman 1/2" plunge router that has split shaft method rather than a conventional collet like PorterCable, etc use. That one sticks but I found that if I tap the nut after loosening it, it comes right out. It's just 1 router out of many I own that does this. I live with it.
hcbph is offline   Top - Reply with Quote
replacing collet on Bosch router SanderW General Routing 1 06-07-2008 11:51 PM
How far to insert collet adapters? mftha General Routing 3 05-28-2008 04:18 PM
Already Problems neuschu Introductions 7 01-22-2008 10:32 PM
Taste ? (about collet) Benny LaBaw Lobby 11 07-15-2007 08:57 PM
Router Collet jammed rmq11 General Routing 3 07-05-2005 09:23 AM
