Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 01-15-2005, 12:03 AM   #11
reible
Supreme Forum King
reible's Avatar
Originally Posted by CanuckBeaver
Just a note on WD-40. WD stands for Water Displacing, and the 40 is the 40th formula tried. TIP! Try scotchbrite pads (light pressure) or fine steel wool.
Reible wrote "OK OK I was a little off it is Bull-Frog...... as in:
www.bull-frog.com
look for the rust remover.......
If you go this way I'd like to hear what you think of the product."
Why do I have visions of you doing a google search of "Rusty + Frog"?
Cheers!
CB
I had alerted to the name because of what I had heard from a friend so I recalled seeing the product mentioned "Rust Removal & Prevention" where someone ask "A fine layer of rust has developed on my band saw tabletop...." The answer was Bull Frog Rust Remover and Bostik TopCote.
See the June 2004 issue of Workbench page 8. I was lucky it was the first copy I looked at and it was right inside the first few pages.... I don't always look to the web to find things but I could also see me doing that search and finding a lot of things other then what I wanted.
Ed
Old 01-16-2005, 01:40 PM   #12
luvmyretirement
New Member
luvmyretirement is on a distinguished road
Thanks for your suggestions everyone. I am going to try to purchase Bull Frog Rust Remover and then apply a coat of wax. I will post my results once I have tracked down the product.
luvmyretirement is offline   Top - Reply with Quote
Old 01-21-2005, 07:17 AM   #13
JamesEMc
Forum King
JamesEMc's Avatar
JamesEMc is on a distinguished road
I seem to recall a similar thread in another forum that advised against using auto wax on unpainted surfaces because many of them contain water - I use Johnson's on my BS as well as on squares, rulers and other items with bare steel exposed, including the old circular saw that I found in an open shed.
Reunite Gondwanaland
JamesEMc is offline   Top - Reply with Quote
Old 02-17-2005, 10:09 PM   #14
reible
Supreme Forum King
reible's Avatar
FYI
My order arrived today for a 16oz bottle of Bullfrog. $11.95 + 5.00 S&H (US) from Klingspor's.
Ed
Old 02-17-2005, 11:19 PM   #15
kp91
Forum King
kp91's Avatar
First Name: Doug
Boeshield T-9 kit (rust remover-rust preventer) seems to be working pretty well for me.
1 John 1:9
Old 02-20-2005, 12:18 PM   #16
eddie blair phillips
eddie blair phillips is on a distinguished road
Originally Posted by Learning Herb
I ues W-D 40 and 400 grit wet dry sand paper and some hard work . But it comes up real nice. Then I use a top grade wood paste wax Like Johnsons .But I do know that wood wax works a lot better than car wax .Car wax drys to hard and is not as slick.
Learning Herb
Good idea Herb gave you the only thing I do different ( I have a humidity
problem ) is after the WD-40 treatment I scrub with a medium steel wool
it gets down deep into the little grooves
Big Ed
eddie blair phillips is offline   Top - Reply with Quote
Old 03-02-2005, 08:05 PM   #17
Dustylayer
New Member
Dustylayer is on a distinguished road
There is another alternative. Try Oxisolv rust remover, followed by Boeshield Rust & corrosion protection. Both products together set me back $20. However, I live in the Seattle area and rust/corrosion is a problem. After all, after living here for more than two years your toes will web together from the humidity and moisture. :-)
Honestly, though. My Jointer, bandsaw tables, and router bit shanks have remained virtually rust free with treatment from Boeshield T-9, after cleaning with Oxisolv. I'm sold on the products, even though a bit costly. I would follow the advice of others though that a light coat of paste wax is a great idea.
My 2 cents worth.
Clay
Dustylayer is offline   Top - Reply with Quote
Removal of router springs for table use pianoman8 The Voting Booth 20 11-09-2008 11:02 AM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 11:57 PM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 11 07-25-2007 03:45 PM
Cubbie's Router Table Cubbie Table-mounted Routing 4 03-19-2005 04:13 PM
