| | #1 |
| Registered User New Member | I am having problems keeping surface rust off tool surfaces. Can anyone suggest the best product to use to REMOVE rust from metal surfaces and also what product is best used to KEEP the rust off. |
| | #2 | |
| Registered User Dedicated Member | Quote:
Hope this helps cfm | |
| | #3 |
| Senior Moderator Supreme Forum King | I read an article in one of the woodworking magazines suggesting WD-40 to be the best surface coating as far as resisting future rust based on their test results. The suggested method was to allow the clean metal to soak in WD-40 for 5 minutes, then to wipe dry. They also had a bunch of methods to remove the rust. I will sort through my collectiion and try to find which issue for you. I have always used WD-40 and scotchbrite to clean my tools.
__________________ Mike |
| | #4 |
| Forum Moderator Supreme Forum King | Ahh.... A chance for a newbie to contribute something Johnsons paste wax is great on the machine surface. Helps prevent rust as well as keep the surface slick and the stock moving freely. Another good choice is Top Coat which is a spray on and easier to apply. Both should be wiped and buffed a little after drying.
__________________ Cheers, Bob Pictures from the shop http://s107.photobucket.com/albums/m292/bnoles616/ |
| | #5 | |
| | #6 |
| Registered User Supreme Forum King | I heard from someone who restores cars he uses a "frog????" I forgot the name but I have also seen it mentioned in woodworking mag's. He says it the best he has ever come across for restoring rusty surfaces. Anyone know what I'm talking about???? I personal like to use wax to protect and lub..... do a search or look around I just put a message out on the subject of wax this past few days..... Ed |
| | #7 |
| Registered User Supreme Forum King | OK OK I was a little off it is Bull-Frog...... as in: www.bull-frog.com look for the rust remover....... If you go this way I'd like to hear what you think of the product. Ed |
| | #8 |
| Registered User New Member | I was suggested to use an auto wax. Once the surface is clear of rust( and if you have one) use a high speed buffer and a finish wax. With car wax there should be no oily residue left on the table that will transfer to your work and should protect it for a while. I know for myself even this is hard to work seeing as that my shop is unheated and I live on the wet coast, but it is definitely better than nothing |
| | #9 |
| Registered User Forum Fanatic | I ues W-D 40 and 400 grit wet dry sand paper and some hard work . But it comes up real nice. Then I use a top grade wood paste wax Like Johnsons .But I do know that wood wax works a lot better than car wax .Car wax drys to hard and is not as slick. Learning Herb
__________________ I try to learn some thing new each and every day ,Learning Herb
| | #10 | |
| Registered User Sr. Member | Quote:
Reible wrote "OK OK I was a little off it is Bull-Frog...... as in: www.bull-frog.com look for the rust remover....... If you go this way I'd like to hear what you think of the product." Why do I have visions of you doing a google search of "Rusty + Frog"? Cheers! CB
__________________ I've sanded so much my fingerprints are gone! Last edited by CanuckBeaver; 01-14-2005 at 04:39 PM. Reason: Spelling and addition of tip. | |
| Router Table Help Which One! | bigroccrek | Table-mounted Routing | 25 | 04-08-2008 10:57 PM |
| Removal of router springs for table use | pianoman8 | The Voting Booth | 20 | 11-08-2007 03:58 PM |
| First and only (I hope!) Router table | CanuckBeaver | Table-mounted Routing | 11 | 07-25-2007 02:45 PM |
| Cubbie's Router Table | Cubbie | Table-mounted Routing | 4 | 03-19-2005 03:13 PM |
