| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Dedicated Member | Hello, I was wondering if anyone happens to know of a lubricant I can use on my mortise & drill bit. My mortise has been honed but I believe that the drill bit itself is overheating due to dullness (which I am going to try to sharpen). I am just guessing. I look forward to hearing any suggestions. Allison |
| | #2 |
| Registered User Supreme Forum King | Not sure you would really want to use "lubricant" for your mortise bit. If your bit is overheating, then it's dull. Sharpen it.
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #3 | |
| Forum Contributer Supreme Forum King | HI Allison I forgot to tell you about the other item that I use ![]() SO BIT & BLADE LUBRICANT """ Teflon """ This unique liquid fluoropolymer spray allows saw blades, router bits, and other cutting tools to cut all kinds of materials cooler and cleaner with less friction. SOMMERFELD'S OWN Bit & Blade Lubricant prevents blade and bit fouling caused by pitch build-up, while it prolongs the cutting life of all cutting tool surfaces including carbide, stellite and high-speed steel. A little spray on the bit and it will cut like a dream... http://www.sommerfeldtools.com/item....d2oz&d=160&b=2 http://www.routerforums.com/table-mo...non-sizes.html ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 11-28-2007 at 07:32 PM. | |
| | #4 |
| Forum Contributer Supreme Forum King | How does Teflon effect wood finishes if overspray lands on the surface. I raise this question because I have seen the result of Silicone overspray, tiny spots all over the surface that the finish would not adhere to.
__________________ Harry |
| | #5 | |
| Forum Contributer Supreme Forum King | Hi Pop Well maybe but I don't put it on the wood I put it on the bit popIt's not Silicone it's a water base Teflon , I also use some made by DuPont called Teflon Multi-Use Dry,Wax Lubricant stays clean no oily film .. I comes in a 4oz.plastic bottle and it works great also.. But I do follow the directions,"allow to fully dry" the Dupont will last 3 to 5 times longer than most Lubricants... When I started to use it, I called Marc Sommerfeld of sommerfeldtools and ask if anyone had problems with rust on the bits becasue of the water base and he said no, he had been using it for years on his bits..with no problems. And that made sense because the water is wiped of by the wood chips and the Teflon sticks to the bit..and as you know the router bit has a very small cutting point most of the cutter is for setting the angle...and holding the carb.blade in place..and will never touch the wood, chips and saw dust yes but not the project stock. ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 11-29-2007 at 01:00 PM. | |
| Home Brew Mortise Pal | trap | Tools and Woodworking | 5 | 06-14-2008 02:05 PM |
| Rounded Mortise & Squared Tenons? | Nickbee | Table-mounted Routing | 15 | 01-16-2008 09:11 PM |
| My mortise jig | guyos | Jigs and Fixtures | 3 | 10-04-2007 11:07 PM |
| Rolling Mortise Jig - the test | simplenik | Table-mounted Routing | 9 | 07-23-2007 11:54 AM |
| Mortise & Tenon System Router questions | kenadian | Table-mounted Routing | 2 | 11-17-2005 04:22 PM |
