Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 12-07-2007, 12:34 AM   #1
jer760
Forum Fanatic
jer760's Avatar
jer760 is on a distinguished road
Default DC for the drill press
Hi all, looking for a better way to tame the dust, chip, shavings my drill press. I use anything from simple drill bits to drum sanders to Forster bits......etc. I tried the setup in the attached photo but found it pretty much useless. any ideas would be appreciated. Thanks in advance.
Jer
Miracle Stick! Made of tough, genuine wood!
jer760 is offline   Top - Reply with Quote
Old 12-07-2007, 07:37 AM   #2
Fourleftpaws
Forum Fanatic
Fourleftpaws's Avatar
First Name: Larry
Fourleftpaws is on a distinguished road
Send a message via Yahoo to Fourleftpaws
Hi jer - Looks like you have the same vacuum system as I do - Ridgid 2.5 tubing with the attached blast gates. I really like that set up.
The only thing I did different than you was to attach the hose at the drill press with a clamp from a outdoor light. I clamp it to the drill press post and then just angle it down by the bit - it collects about 90% of the waste being produced.
Larry
"Have you hugged your pet today"
Fourleftpaws is offline   Top - Reply with Quote
Old 12-07-2007, 10:18 AM   #3
jer760
Forum Fanatic
jer760's Avatar
Yep, its the Ridgid kit all right, I'm pretty pleased with it so far. I'm using a 1hp dust collection system from princess auto (early xmas present) with it, much quieter than my shop vac. As for the drill press, I'll fool around with your suggestion and see what I come up with, thanks.
Jer
Old 12-07-2007, 10:27 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi jer760
You may want to give this a shot,,see the white peg board on the wall,,,do you have some more around if so ,make a box frame about 3" tall/deep for your sub base that you now have on the drill press,,,cut some white peg board to fit the frame, make it so it sides in a slot/rabbit in the frame,,(for quick cean out) , now drill the holes out to 1/2" (with a hole saw,from both sides,most use a 1/4" drill bit, this will take the guess work out of lining up the drill for new hole sizel) then put in a hose pickup on the back side, slip the hose on and you have just made a vac plate for your drill press that you can use for many jobs...i.e. drilling ,sanding,etc.besure to put in some rib supports in the frame box, you want to make it flat and strong..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-07-2007, 11:09 AM   #5
angus
Sr. Member
angus is on a distinguished road
I have a question redarding the Ridgid Dust Collection System - Does it work?? Would it be OK say for a belt sander, band saw. miter saw, and maybe a table saw. Will it handle a vaccum larger than a shop vac ie: Jet Dust Devil.
Thank you
Angus
angus is offline   Top - Reply with Quote
Old 12-07-2007, 09:08 PM   #6
Fourleftpaws
Forum Fanatic
First Name: Larry
Angus - I will jump in here - I really like the system. Does it work - yes, very well. I have the system hooked to a 6 gallon Ridgid vacuum. I have the system hooked to 2 - scroll saws, band saw, sander, table saw and drill press. Each has its own blast gate to close off when that machine is not in use. I had it hooked to a 1 HP Grizzle vacuum system and worked very well with that, until it was dedicated to my router table.
Dang it BJ - now there is another system I am going to have to try, but that would work just great as I already have the vacuum hose there.
Larry
Old 12-07-2007, 09:23 PM   #7
seawolf21
Forum Fanatic
seawolf21's Avatar
First Name: Gary
seawolf21 is on a distinguished road
Default My DC for the drill press
This is a simple thing to make. I use it all the time. You just stick your vac hose in the thingy and suck!
Gary
seawolf21 is offline   Top - Reply with Quote
Old 12-08-2007, 03:04 AM   #8
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Great looking shop fourleftpaws. Have you ever thought about buying a RIGID tool? Just asking.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 12-08-2007, 01:14 PM   #9
jer760
Forum Fanatic
jer760's Avatar
Originally Posted by bobj3
Hi jer760
Thanks for the replies, I found Bobj3's idea the most intriguing so I knocked a prototype of your dust vacuum plate out of some reclaimed scrap just to see how well it would work. The verdict is very well, much better than what I had going on.
Thank you very much Bobj3, and fourleftpaws, I gotta say that is one of the nicest shops I have ever seen. Mine is a work in progress and I've got to say you just raised the bar.
Jer
Old 12-08-2007, 01:35 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome jer760
You did a great job on the vac box
I made one along time ago and it works great to keep the shop clean and the drill table surface clean with just a little sweep of the hand and it's down the tube so to speak
It also works well when you need to do a bit of sanding, many of the new type hand sanders come with a vac pickup/bag on them but they still make a mess.....
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Need info Chicago 5-speed drill press Birchwood Tools and Woodworking 14 10-22-2008 04:10 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 12:20 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 11:43 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 10:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 10:03 PM
