Rate This Thread - Sanding Tips.
Thread Tools Display Modes
Old 01-15-2005, 06:51 PM   #1
pmspirito
Forum Fanatic
pmspirito's Avatar
pmspirito is on a distinguished road
Thumbs up Sanding Tips
I take two 6 inch diameter peel and stick adhesive (PSA) sanding disks and stick them together for quick hand sanding. They become rather stiff when stuck together and are very sturdy and hold up well. I stick together a 150 and a 220. Or for general carpentry work a 60 and a 150.
If you have never used one of those rubber blocks for cleaning sanding belts and disks you are in for a real treat. They really work and your belts and disks will last a very long time.
Although the new 3M sanding products sold at HD are significantly better than the previous handyman stuff you need to try the sanding products made by Klingspor available on line at www.woodworkingshop.com or at one their 4 stores in North Carolina. Abrasives are their speciality and you can tell the difference.
pmspirito is offline   Top - Reply with Quote
Old 01-15-2005, 11:02 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I do the bulk of my sanding using random orbit air sanders.(DA's) I have one I use with under 100 grit, and a newer one I use with 120 and up. These always wear out on the outer radius while the center is barely affected. When I remove them I fold them in half and use them for hand sanding with the benefits pmspirito described.
I ran across an article which changed the way I sand things. It suggested using no finer than 150 grit for finish sanding since this allows for all finishes to adhere properly to the wood. Before I would of sanded to at least 220 with no thought that it could cause the finish to fail prematurely.
Old 01-16-2005, 04:45 PM   #3
pmspirito
Forum Fanatic
pmspirito's Avatar
I just experienced the "too smooth" syndrome on some front porch columns I built up out of 2x pressure treated pine. I used, for the first time, Min-Wax epoxy filler to fill the knots etc. It sands glass smooth. I sanded the columns with 220 which on the PT was ok but on the filler made it too smooth. I was spraying latex primer with a bit of Floetrol added as a retarder. The paint took to the wood perfectly but slid right off the slick epoxy filler. I went back and resanded with 150 and reshot with the same paint mix and it game out great.
A brochure put out by Min-Wax on refinishing floors says: "Sand the floor for a third time with 100 grit sandpaper. If floors are not going to be stained, then follow this sanding with a final sanding using 120 grit sandpaper."
So smoother is not always better. Apparently the stain will not soak in as well if the wood is too smooth.
"WANTED" one to three line router tips BobandRick General Routing 38 01-15-2008 11:24 AM
Mounting a router plate questions / tips? Nickbee Table-mounted Routing 3 11-29-2007 10:26 AM
Sanding paper everywhere... simplenik Tools and Woodworking 7 06-02-2007 12:57 AM
Router tips trap Tools and Woodworking 0 02-28-2005 10:01 PM
Amateur Router Tips or Two reible Jigs and Fixtures 7 11-17-2004 10:44 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
