Thread Tools Display Modes
Old 01-09-2008, 08:51 PM   #1
vapochilled
Forum Fanatic
vapochilled is on a distinguished road
Default tenoning jig
I've seen lots of tenoning jigs for good size table saws, but only have a ryobi BTS10S, which is very small and does not use "standard" mitre slots.
I did make up a cross cut sled for it which works well, but now I need to cut frames to make cabinet doors and draw fronts.
The tenons are 2 1/4" long 1/4" wide in Oak.
The fence that comes with it is not going to be of help, it's not square to the bed and can't be adjusted.
So I was looking at tenoning sleds, but all the plans I've seen are for full size saws.
Does anyone, or has anyone got or seen something for the more Sq inch debilitated amongst us
vapochilled is offline   Top - Reply with Quote
Old 01-09-2008, 09:31 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
The easy way is to pickup the jig from Grizzly and make your own track part for it so you can use it on your saw...
Or you can make your own, easy from sq.1,they are easy to make..
Tenoning Jig
http://grizzly.com/products/Tenoning-Jig/H7583
tenoning-jig-470.jpg  tenoning-jig-471.jpg  tenoning-jig-469.jpg  tenoning-jig-teton.jpg
Bj
Old 01-09-2008, 10:18 PM   #3
vapochilled
Forum Fanatic
Tempting to buy one, but I'm not sure it will get used enough right now.
I suppose I could lay the stock flat on the router table and and "nibble" the material away from each side. Then it would just leave the slots to cut.
I have an 8" dado set, just need to hold and move the stock.
Hmmm, thinking cap on time!
Old 01-09-2008, 10:40 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
Without the jig it can be tricky on the table saw,,,
You can make a sled to fit over the saw fence but it must be dead on...
The Router table will do it, but it can be tricky to get it right on,,
if you have a coping sled it will come out true...using slot cutters..
To put the slot in , that's a easy one to do, make a new base plate for your plunge router and put a bearings/pins in the base..
If you want to see the jig for that one just ask and I will post it..
pictures below
http://www.routerforums.com/attachme...ase-plate-.jpg
http://www.routerforums.com/attachme...g-jig-8039.jpg
http://www.routerforums.com/jigs-fix...ge-router.html
Bj
Old 01-09-2008, 11:10 PM   #5
vapochilled
Forum Fanatic
I'm terribly new at panels and frames, but I can't see how I can use the to form the frame joints?
cope and stick router bits would be the best, but they are not cheap, certainly more than that grizzly tenoning jig I'd guess.
God forbid that I have to send the tenon saw away for sharpening and do this by
h h h h hand
Old 01-09-2008, 11:19 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
Well if that's what you are doing the R & S sets are cheap and they do make joints quick and easy and they hold very well..
http://cgi.ebay.com/2pc-1-2-SH-Quart...QQcmdZViewItem
http://cgi.ebay.com/3pc-15-Panel-w-b...QQcmdZViewItem
h h h h hand
Bj
Old 01-09-2008, 11:23 PM   #7
vapochilled
Forum Fanatic
Right, they would be great for the internal cuts, but what about the frame joints, thats what I'm after.
I think it's called a sliding tenon? (open at one end) I could mitre it, but thats not what "she who must be obeyed" wants lol
Old 01-09-2008, 11:31 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi David
" frame joints " the R & S set will make all the joints for the frame..
" sliding tenon? " = ???
What are you making ???
If you want to make a sliding tenon joint you may want to use the T & G bit set,they come with shims so you open the joint up just a bit so it can slide..but still have the edges to keep it running true..
http://cgi.ebay.com/2-pc-1-4-Shank-T...QQcmdZViewItem
Bj
Old 01-10-2008, 07:14 PM   #9
vapochilled
Forum Fanatic
this is the type of joint I'm doing, material is 2 1/4" so the router bit set won't work, it has to be either routed flat, or done with a tenoning jig I think
Old 01-10-2008, 08:00 PM   #10
reikimaster
Forum Geek
reikimaster is on a distinguished road
Looks to me like you could do the tenon with your router and the "mortise" with a saw and chisel. Those are big joints. You could even bandsaw the mortise since it's open ended or use a nice Japanese pull saw (c'mon... you know you want one) and then refine it with a sharp chisel. I think you'll spend more time trying to figure out how to do this with power tools than it would take you to just go ahead and dive in with hand tools
reikimaster is offline   Top - Reply with Quote
TS Tenoning Jig Router is still my name Tools and Woodworking 11 06-30-2008 01:44 PM
Tenoning jig AxlMyk Tool Reviews 14 03-31-2008 10:34 PM
Tenoning jig AxlMyk AxlMyks' stuff 6 03-01-2008 07:26 PM
Ladies and Gentleman - it's RRRolling (TS Tenoning jig) simplenik Tools and Woodworking 8 06-06-2007 06:29 AM
Tennons on my router Densa Jigs and Fixtures 15 12-31-2005 02:49 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109
