| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Forum Fanatic | I'm attempting to make a dining table out of a red pine harvested from the cottage lot. The top is made from 1.5" x 8" boards that I laminated together with the help of biscuits. The problem I'm having is the tabletop developed a wow in one corner. Is there a trick anyone can suggest to straighten this without sacrificing the thickness of the top? I have it all clamped down to a flat surface now and while it is getting better, I'm not sure if there isn't a better way to fix this. Thanks in advance.
__________________ Jer Miracle Stick! Made of tough, genuine wood! |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi jer760 This just one way ![]() Build a sub frame,, ( sometimes called a dust frame) in case work, and use pocket hole screws to pull the top down in place,, the pocket holes screws will act like clamps...you can hide the sub frame with a shirt part under the table top... ====================== Quote:
| | #3 |
| Registered User Forum Fanatic | Okay, I think I get what you're saying and will try it, do you think wetting the top would help?
| | #4 | |
| Forum Contributer Supreme Forum King | HI jer760 No I would not put water on it ,, don't forget it was a tree at one time and will always want to go back to that form...bow/warp/bend/soak up water,etc.... Just do what you are doing clamp it down flat to your work bench, then put the sub frame in place and lock it in and pull it back in place with the screws.. ============ Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-17-2008 at 10:45 PM. | |
| | #5 |
| Registered User Forum Fanatic | Ok, will do and thanks very much for the quick response.
| Cnc advice needed | mderzio | CNC Routing | 5 | 04-09-2008 08:32 AM |
| need advice for inserting rosseau router plate into bench dog promax cast iron table | sf_basilix | Table-mounted Routing | 7 | 02-21-2008 07:00 PM |
| Advice sought on router options | jcarter137 | Introductions | 2 | 02-02-2008 09:57 PM |
| Seeking advice - safety and feasibility | trex021 | Shop Safety | 5 | 04-09-2007 04:45 PM |
| Some advice before going to see the Dr. | Joe Lyddon | Lobby | 1 | 02-13-2007 09:18 PM |
