Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 01-22-2005, 12:19 AM   #1
Warren
Jr. Member
Warren is on a distinguished road
Default Shaper question
I've never used one (routers have covered all of my needs so far). But, a friend of mine recently purchased a used one which can be operated in reverse. Why would you want to reverse the cutter direction? Are shaper cutters made to operate ineither clock-wise or counter? I told him I would ask the experts and get an answer for him.
Warren is offline   Top - Reply with Quote
Old 01-25-2005, 04:25 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
The reverse feature is for clearing jams, not for cutting.
Old 01-25-2005, 05:16 PM   #3
reible
Supreme Forum King
reible's Avatar
I have never seen one with a reverse..... How is it done with the motor or belts????
As far as I know from the shapers I've used/seen the cutter is mounted on a shaft with a special washer the fits in a groove then the nut. Even with that spinning backwards would worry me.
I'm guessing that aniceone2hold is right, I sure don't think one would want to cut that way.
Ed
Old 01-25-2005, 06:46 PM   #4
Warren
Jr. Member
Thanks Mike. That's one of those answers where you shrug the shoulders and slap the forehead when you hear it. Pretty obvious once you think about it.
ED, I'll get back to you on that after I talk with Jim, my friend with the shaper.
Old 01-25-2005, 07:56 PM   #5
PEARCO
Jr. Member
PEARCO's Avatar
PEARCO is on a distinguished road
Warren;
The reverse switch on a shaper is for clockwise and counter clockwise cutters for different cutting operations. For example if you are using a panel rasing cutter, you will want to refference off the shaper table top. On the next operation, you may need to feed in the opposite direction for a different cutter.
Many profiles are designed to cut from different feed directions. It also is desinged to operate with different power feeds - forward and reverse systems.
This design works with mounting of the power feeds. I assure you it is not to clear a jamb. In my forth years in the buisness I have never seen a shaper jamb or one without a reverse switch.
Jim
PEARCO is offline   Top - Reply with Quote
Old 01-25-2005, 09:04 PM   #6
reible
Supreme Forum King
reible's Avatar
Originally Posted by PEARCO
Warren;
Jim
Thanks for clearing this up for us.
Now I was worrying about my memory.... how could I have missed this feature..... I don't remember a method of making it run anything but counterclockwise....
But as luck would have it I still have the book (not the shaper) and the book was printed in 1952 (age of the shaper unknown) and I have to tell you the old sears one did not have any method of making it run backward nor is it mentioned or shown to do so.
I don't recall that feature on the ones in school either but maybe I just don't remember..... or maybe I "knew it all" and didn't pay attention.
It makes sence that they could do that, that would also let you use a different profile on a cutter by having it "upside down" It also explains why some of the cutters I have that I never could figure out how to use the "other" profile.
I know I learned a lot from this post..... good question and even better answer..... it is good to learn from those that know.
Thank YOU!
Ed
Old 01-26-2005, 12:02 AM   #7
Warren
Jr. Member
Jim,
Thanks for the information. My friend has yet to fire the machine up. I'm telling him that all of the reading and research I did to get the answer is worth a couple of hundred feet of the molding of my choice.
Seriously, thanks to all of you for the help.
Old 01-26-2005, 03:28 PM   #8
Senior Moderator
Supreme Forum King
Well dont I just have egg all over my face! I learned from this too. I was unaware that you could feed either direction but it makes good sense. Thanks for correcting my mistake Jim!
Old 01-28-2005, 06:29 PM   #9
hcbph
Dedicated Member
hcbph is on a distinguished road
My shaper has a reversing switch on it, and I use it all the time. Left and Right feed cutters exist. Additionally sometimes you want to use the cutter either on the top or bottom of a particular cut. It really adds to the flexibility of your cutters.
hcbph is offline   Top - Reply with Quote
Router vs. Shaper rstermer General Routing 8 05-11-2008 05:10 AM
DC Question angus Lobby 3 03-31-2008 08:29 PM
shaper and routers rambling Introductions 2 02-12-2008 05:22 PM
Introduction and question AlanO Introductions 3 01-26-2008 03:56 AM
router table or shaper? flyboy8224 Starting Off 6 12-03-2007 02:39 AM
