| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Dedicated Member | anyone here use the harbor fright mobile base they sell for 49.00 ? was thinking of making my own out of 1 1/2 channel weld the corners and add some mounts for wheels. but by the time i was done purchasing the supplies i would be close to the cost of this 1. it is for my new band saw so im worried about being stable |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi vegeta88 I would suggest the one below,, because most band saw are bit top hvy. and they do like to tip,, the mobile base below will let you get the band saw almost on the floor but still let you move it around when you need to pull it out from the wall.. ![]() http://www.grizzly.com/products/Mini-Mobile-Base/G8683 I should note I have 3 of them and they do the job well plus you can lock them in place.. with the two hand knobs..One for the band saw one for the jointer,one for the grinder all top hvy.tools. =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-27-2008 at 06:40 PM. | |
| | #3 |
| Registered User Supreme Forum King | HI vegeta, Bob just gave you a great listing for a mobile base. These are strong, sturdy and as he said, you can lock them in place. ![]()
__________________ Ken "A VETERAN" "Whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown |
| | #4 |
| Registered User Dedicated Member | looks good and not much more in cost thanks bob |
| | #5 | |
| Forum Contributer Supreme Forum King | You'er Welcome vegeta I also do alot of welding and I just can't buy the steel and the wheels and the other parts and make them as cheap as they can sell them ,,, ============ Quote:
| | #6 |
| Registered User Dedicated Member | good thing i measured first foot print on my saw is 20x25 will need the heavy duty model to fit wow at 81.00 delivered may reconsider making 1 wheels cost 25.00 and i think there is some 2 inch Channel at work i can take home. |
| | #7 | |
| Forum Contributer Supreme Forum King | Sounds Good vegeta88 It's not big deal but take a hard look at the picture you will see sq.tubing that slide into each other and hold the frame as one kart ,they have two bolts that screw into them on each end and they have about 3" of steel inside the other so to so you can pull it out by 4" more in total on each part and then just tack weld the tubes in place..or just use one bolt on each end of the sq. tubes.. Just one more note you can also use 1 1/2" sq.wood stock in place of the side in steel parts...you may have seen the Make Your Own base karts use this type of setup...( rip some 2 x 4 stock up and you have the parts you would need to make it fit just about any tool in the shop) quick and easy fix. Or use the old pallets you have around the shop (most are Oak)Power Tool Mobile Base at 40.oo bucks ▼ http://www.rockler.com/product.cfm?p...er=tool%20base ========= Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-28-2008 at 10:13 AM. | |
| | #8 |
| Registered User Dedicated Member | update. finely got batteries for the camera today thought i would share my try at a mobile base Last edited by vegeta88; 03-08-2008 at 06:06 PM. |
| | #9 |
| Forum Contributer Supreme Forum King | Nice job vegeta88 Just asking,what did it cost you to make your own ? ![]() look s like some 1" x 2" tubing and some flat stock, is that right ? =========
| | #10 |
| Registered User Dedicated Member | wheels at HF... 2.99 each 4 square plate in the middle 2.00 each 1X2 10 feet 10.00 2 feet of channel 4.00 pretty cheep and it was fun |
| Porter Cable 890 series defective routers | Mike | RouterForums.com News & Feedback | 31 | 09-07-2008 08:24 PM |
| Colt plunge base | bobj3 | Jigs and Fixtures | 19 | 04-01-2008 08:54 PM |
| Model 320.17542 and table routing | trap | Table-mounted Routing | 41 | 07-03-2007 12:37 PM |
| Hitachi m12vc sub base question | Cactus Carl | General Routing | 4 | 09-12-2005 09:29 AM |
| Centering Base Plate | -Sam- | General Routing | 15 | 01-04-2005 11:15 AM |
