Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 03-07-2008, 12:35 AM   #1
jer760
Forum Fanatic
jer760's Avatar
jer760 is on a distinguished road
Default opinions on radial arm drill press please.
I would like a radial arm drill press that has speed change via a lever ( would rather not screw around with belts and pulleys ), laser lineup, enough ooommmf for the most demanding jobs and I would prefer a bench mounted unit...............am I asking too much??? Any suggestions would be appreciated.
Jer
Miracle Stick! Made of tough, genuine wood!
jer760 is offline   Top - Reply with Quote
Old 03-07-2008, 09:06 AM   #2
kp91
Forum King
kp91's Avatar
First Name: Doug
This one has a couple of your desires, Heavy, lots of power, big capacity, etc.
http://www.grizzly.com/products/Radi...ll-Press/G9969
I'll keep my eyes open for a couple of others.
1 John 1:9
Old 03-07-2008, 10:00 AM   #3
kp91
Forum King
kp91's Avatar
First Name: Doug
Cheap add on laser........ OK, it's a bore sight laser, but it might work....
http://www.sportsmansguide.com/net/cb/cb.aspx?a=195745
1 John 1:9
Old 03-07-2008, 10:12 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi jer760
Just my 2 cents
NOT made for the normal user of a drill press ,, most don't come with a sub table,that's to say one you can crank up or down..under the drill motor..
Plus they must be bolted down to a good work bench alot of the mass is over the center point.
But I will say they are great if you are in to making chairs,etc.
They are hard to get back to zero point without taking some stroids to man handle it back...
Just a note on the laser light,, I have one on my drill press,it's clamped to the quill ,it's ok but not that big of a deal...
I'm sure you can get one from Sears..if you want to use one.
opinions-radial-arm-drill-press-please-7085.jpg  opinions-radial-arm-drill-press-please-7086.jpg  opinions-radial-arm-drill-press-please-7088.jpg  opinions-radial-arm-drill-press-please-7089.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-07-2008, 02:40 PM   #5
jer760
Forum Fanatic
jer760's Avatar
Thanks for the replies fellas, the Grizzly looks like a bit more than required in my humble shop not to mention the lack of availability in Canada. I'm going down to the local Sears right away to check out the Craftsman because I'm beginning to believe that radial arm is not going to happen for me. Below is the only one I found available to us Canucks that was close but I believe it'll be underpowered. I agree that the laser is not that big a deal but with my eyes not being what they once were I thought it might be helpful. I just hope this will be a tool that's with me for the long run so quality is first and foremost. Again, thanks.
Radial arm drill press.
Jer
Old 03-07-2008, 02:46 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Sounds good jer760
Grizzly also makes/sells a light duty one.
http://www.grizzly.com/products/5-Sp...ll-Press/G7945
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 03-07-2008, 04:57 PM   #7
berry
Sr. Member
berry's Avatar
berry is on a distinguished road
I know this doesn't meet all you 'needs' but have you considered a used Shopsmith? The drill press action is often thought to be Shopsmith's best feature (I don't agree, but that's neither here nor there for this discussion). Good horsepower, very adjustable, variable speed from 700 to 5000 or something like that. You can find good used units all over North American. I see them on CL for under $300 here in the midwest. If it takes up too much room you can cut off the 4 horizontal tubes and make it a shorty.
The invention of the lathe was a turning point in history.
berry is offline   Top - Reply with Quote
Old 03-11-2008, 04:50 PM   #8
jer760
Forum Fanatic
jer760's Avatar
Well, after seeing the laser sights in action I decided that this was just a gadget that was not really a necessity. I looked at the General tool's DP's and loved everything but the price ( whew ). After reading some reviews I was led to Delta's DP350. This is the one I settled on, the variable speed feature is one a guy will use for sure. I now just have to figure out a subtable and dust collection. Thanks all for the responses, they helped alot.
Jer
New Drill Press bobj3 Tools and Woodworking 27 08-02-2007 11:11 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 7 07-15-2006 12:20 PM
Table Top Drill Press Motor 'Anemia' jonnyboy63 Tools and Woodworking 3 03-25-2006 11:43 PM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 10:07 PM
Drill Press -Sam- Tools and Woodworking 18 07-24-2005 10:03 PM
