| | #1 |
| Registered User Sr. Member | So I'm taking the next step and getting a dedicated rip blade. I've been happy with my combo blade, but I'm doing more and more of my own ripping and decided it's time to get a blade. I'm looking at the Freud LM72R, 24 tooth, "industrial," rip blade for about $50. I have also found the LM74R, 30 tooth "glue line rip" for about $60. EDIT: there's also the LM74M which is the same as the LM74R except that it doesn't have the red coating, for ~$50. I wanted to see if anyone has experience with these. Is the extra $10 worth it? I thought fewer teeth was better. I've been very happy with my freud combo blade. I can't afford a WWII, so don't go there. I'm trying to keep it around $50 if I can. Thanks for any input. Last edited by rprice54; 05-02-2008 at 02:40 PM. |
| | #2 |
| Retired Moderator Supreme Forum King | I have the LM72 and I like it. I don't use it often as I usually use a Freud combo. Many like the glue line rip but I find the LM72 works well. Corey
| | #3 | |
| Retired Moderator Forum Geek | Quote:
Porter Cable has the "Razor" 50 tooth blade that I found to be great for ripping. I buy it at at Home Depot for about $39.00 I have 2 of them and the first one is still doing the job after ripping Black Walnut, Cherry, Hard Maple for making about 30 end grain cutting boards. I have the 30 tooth Frued but have not tried it yet. I am thinking about check out the Harbor Freight blades to see how they hold up at work, we rip well over a 1000 BF of Black Walnut, Cherry, Cedar, White and Red Oak daily. For 9 to 16 Dollars (last years prices) I am going to try one or 2 to see how they hold up. Just my 2cents. Randy
__________________ Regards Randy PC Support Forums, Free on line virus Scan, The Parasite Fight, Subratam.org -> Kill Spyware Forums A.S.A.P. Proud member since 2004 ~ Twin Oaks Mill | |
| | #4 |
| Registered User Forum King | I vote for the Freud glue line rip blade. It's full kerf, heavy, and cuts like you wouldn't believe. Lately, I've been buying nothing but Freud.
__________________ Mike - Retired FoMoCo Tradesman My Gallery @ http://www.routerforums.com/axlmyks-stuff/ |
| | #5 |
| Registered User | You might want to take a close look at the specs. The glue line says only up to 1" wood. So if you are doing thicker the 72 is the one for you. I use the 72 for ripping some pretty thick stock. Currently doint 12/4 walnut. |
| | #6 |
| Registered User Sr. Member | thanks for the info. I had a porter cable razor, and it did a good job, until I chipped a tooth on some polycarbonate... then I got my freud combo blade, which I have been very happy with. I'm looking at these two specifically because they are full kerf which I want for my ripping blade. I will probably go with the glue line rip as it has a thicker plate and MOST of what I'm ripping is 3/4 stock. I'm sure it will handle more, probably just not as fast or as clean. |
| | #7 |
| Registered User Jr. Member | I have the Freud LU87 thin kerf rip blade. I am very satisfied wih it. I ripped about 1000 lineal feet before I had it sharpened. It runs very true. I have used the Harbor Freight blades. They are garbage. I do not consider them safe to use as the plate is so thin that they wobble. |
| | #8 |
| Registered User Sr. Member | I found the LM74 without the red coating for $50 and went with that. I just bought about 80bf of 4/4 and 5/4 walnut, I'll let you know how it goes. |
| | #9 |
| Registered User Sr. Member | The blade worked like a champ. Very little rework needed before I glued up some panels. I set my TS up so when I have the fence on the left of the blade, it's dialed in to the full kerf ripping blade, and with the fence to the right, it's dialed in to the thin kerf combo blade. most of my work left of the blade (besides ripping) is done with my miter fence anyways. works great. this is my third freud blade, I may not ever go to another brand, I am very happy with all three (one on my circ saw). |
| | #10 | |
IMHO, Freud can't be beat for blades. ![]() Now, there are some who'd recommend Forrest, I've yet to try one out, unfortunetly, they are tad too high in price for me. ![]()
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | |
| Forest 10" 80 tooth Chopmaster Blade | rstermer | Tool Reviews | 0 | 05-13-2008 02:31 PM |
| Saw Blade Tip | bobj3 | Lobby | 1 | 09-21-2007 09:58 AM |
| "Lo-tech" table saw blade alignment | simplenik | Tools and Woodworking | 1 | 07-08-2007 05:06 PM |
| Blade Questions | RustyW | Tools and Woodworking | 16 | 12-30-2006 05:45 AM |
| Tablesaw blade guards | delroy33 | Tools and Woodworking | 22 | 12-31-2005 05:17 PM |
