| | #1 |
| Registered User Forum Fanatic | I did not buy the sander from stockroon Supply, but I called them about the angle you cut sand paper. They told me it is the same as the paper that comes on the drum.. bobj or challenge can you give me a hint. Bud
__________________ The Geezer |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi Bud It's cut on a 45 deg. a sharp 45...with the tip cut off ,if you want a snapshot just ask and I will post one... ========== Quote:
__________________ Bj Last edited by bobj3; 05-06-2008 at 10:07 PM. | |
| | #3 |
| Registered User Forum Fanatic | Thanks bobj... After thinking about, I saw lines on the drum. Have a lot of vecro laying around. Put it on backwards, following the lines on the drum. cut the end off, took it off turned it over and went to the left side and put it on. There is no cut off end, like the video on then at stock room. I will cut one at 45 degrees and square it off and see if that is better. Thanx again Bud
| V Drum Sander | trap | Tools and Woodworking | 4 | 05-03-2008 11:40 PM |
| Drum Sander | trap | Tools and Woodworking | 10 | 04-03-2008 09:39 AM |
| Drum sander help please? | Birch | Tools and Woodworking | 6 | 04-19-2007 03:57 PM |
| Delta 18-36 Drum Sander | dustmaster | Tools and Woodworking | 1 | 08-02-2005 10:31 AM |
| Performax 10-20 plus drum sander | reible | Tools and Woodworking | 2 | 01-02-2005 06:55 PM |
