Rate This Thread - Outfeed/assembly Table..Need ideas!.
Thread Tools Display Modes
Old 05-13-2008, 01:07 PM   #1
deck99
Sr. Member
deck99 is on a distinguished road
Default Outfeed/assembly Table..Need ideas!
I recently built a really heavy duty 4'X6' outfeed assembly table. Heavy is the key word. Major over kill...anyway. I just bought a new truck and want to keep it in the garage so I am forced to consolidate my workshop. I am just curious what you guys use for an assembly table....outfeed table...etc.
Pics would be great. I'm trying to see how small of a table I can get away with.
Thanks,
Deck
deck99 is offline   Top - Reply with Quote
Old 05-13-2008, 01:41 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Deck
I use a door size drop down table for assemby, it's hanging from the work bench with 3 hinges and is supported by one 2 x 2 sq.pole that holds just about anything I put on the table...assembly table is always a PIA ,,and I'm a collector of junk boxes,jars,spray cans you name it gets stuck on the work bench BUT the drop down table stops me from doing that once it's down it's clean
and ready for the next assemby job...room in most shops is always hard to come by and the drop down table takes care of that need for me, like you from time to time I need to get the truck in the shop ..
I also have a plate that's inlayed for the pocket hole system to make it easy and quick to put things together,,, I just hate to work on the floor, my floor in the shop is not level but the drop down table is...
In the snapshots below you will see a green ironing board under the top it's no longer in place because it was not needed for support, the table top is the same height as my table saw,router table.RAS,etc. so I can use it for a out feed or infeed table also...
outfeed-assembly-table-need-ideas-shop.jpg  outfeed-assembly-table-need-ideas-shop1.jpg
Old 05-13-2008, 03:39 PM   #3
Doyle
Forum Fanatic
Doyle is on a distinguished road
Hi Deck
To use a door as a drop down is the way to go. I built a four foot drop down on the far end of the 16' work bench. I glued two 3/4" plys and used a piano hinge. Every thing is great BUT, But my nice long bench with storage and all -- IS TO HIGH -- I did not think properly and some day I will have to take it apart and lower it to the same height as table saw etc. It pays to think ahead. Take care
Our tools and machines never take prisoners!
Doyle is offline   Top - Reply with Quote
Old 05-13-2008, 06:32 PM   #4
nzgeordie
Forum King
nzgeordie's Avatar
nzgeordie is on a distinguished road
Deck. I've done pretty much the same, used a door mounted on a wheeled trolley with lockable casters. The door is removable usually hangs on the wall until needed. I've made all my tools movable in the same way on trolleys with lockable wheels (band saw, router table, table saw) and all at the same height so's I can use the table as an outfeed for all of them and push the tools I'm not using into a corner as my shop is quite small.
Pete
I've cut it twice and it's still too short! But only at one end.
nzgeordie is offline   Top - Reply with Quote
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 10:57 PM
First and only (I hope!) Router table CanuckBeaver Table-mounted Routing 11 07-25-2007 02:45 PM
Ideas for a beaut Router Table. Mickyg General Routing 1 01-24-2006 12:56 PM
Cubbie's Router Table Cubbie Table-mounted Routing 4 03-19-2005 03:13 PM
