Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 02-08-2005, 10:47 PM   #1
Drick
Member
Drick is on a distinguished road
Default Dadoes, grooves, and rabbets
Are there any general rules or guidelines or common sense (which I don't have) principles on how deep to make a dado or groove? I would imagine it ties into the thickness of the wood, but how deep is too deep, not deep enough, and just right?
Drick
Drick is offline   Top - Reply with Quote
Old 02-09-2005, 11:59 AM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Drick, I have never seen any published formula for the "correct" amount of depth for a dado. I use 1/2 the material thickness for a strong joint, less if it is simply a channel for sliding a panel into. The main thing is to be sure you have enough glue surface to hold the joint together, or to prevent your panel from falling out. On a project like a bird feeder you can cut a 1/8" deep dado to slide a piece of plexiglass into and it will be plenty strong. If you were building a window you would need more support for the glass, perhaps 3/8"? Base your decision on the type of project as well as the material you are using.
Old 02-17-2005, 12:33 PM   #3
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
I always use 1/2 the material thickness. Why? Just think about how to make the cut list for your materials. If your cutting away 1/2 of the material thickness then your leaving 1/2 of the material thickness right. 1/2 for each side means that to get the shelf size for that cabinet your making 1/2 material thickness X 2 sides = 1 material thickness.
Example: 24" wide cabinet 48" high and 3/4" thickness of material.
3/8 X 2 = 3/4" So the length of shelves are ?? Right 1 material thickness smaller than the 24" width 23 1/4" it is easy to figure out.
That's why I make the depth of cut on all dados, grooves and rabbets 1/2 of the material thickness.
Rick and Bob
The Router Guys
