| | #1 |
| Registered User Forum Geek | Can someone tell me what a 1 1/4'' Overlay 2-Way Face Frame hinge is. Blum makes them and they are sold from Rockler. Does it mean your door is 1 and 1/4 bigger than the cabinet face frame. Thanks Steve Bolton |
| | #2 |
| Forum Contributer Supreme Forum King | Hi SB That's what it means BUT the norm is 1/2" overlay...for most door cabinets.. ==========
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #3 |
| Forum Contributer Supreme Forum King | This is what one looks like.
__________________ Harry |
| | #4 |
| Registered User Forum Geek | Thanks Harry. Apparently easy to install. sb |
| | #5 | |
| Forum Contributer Supreme Forum King | Hi SB Yes and No, they are if you use the right jig... Rockler sells a neat one for about 10.oo bucks , then you can use your router to install the hinges.. Or you buy a high end one for about 175.oo bucks.. =========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 06-16-2008 at 09:38 AM. | |
| | #6 | |
Just teasin ya my friend. ![]()
__________________ Ken (On temporary leave of abscense) "A VETERAN" "Wether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a blank check made payable to "The United States of America", for an amount of "up to and including my life". That is HONOR, and there are way too many people in this country who no longer understand it." -Author Unknown | |
| | #7 |
| Registered User Forum Geek | I couldn't find the one at Rocklers. Any one know of it? sb |
| | #8 | |
| Forum Contributer Supreme Forum King | Hi SB Here's a link ![]() http://www.routerforums.com/jigs-fix...hinge-jig.html ========== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ | |
| | #9 |
| Registered User Forum Geek | Sweet. So you use a standard guide collar? I see you can buy a drill bit that is 35 mm. Does that work? sb |
| | #10 | |
| Forum Contributer Supreme Forum King | Hi SB Yep a standard brass guide will do the trick.. ![]() 35mm bit... Yes but not with that jig, only with the high end jigs... I did make a high end jig out of MDF and plywood that works well but it must be used in the drill press...or with a good havy.duty elec.drill,, the 35mm bit hogs out tons of chips at one time. ==== Quote:
| Concealed Hinge Jig | bobj3 | Jigs and Fixtures | 11 | 02-24-2008 02:43 PM |
| Anyone own one of these hinge mortisers? | S Bolton | Jigs and Fixtures | 20 | 10-26-2007 08:46 PM |
| Slotted Hinge Installing | challagan | Tools and Woodworking | 17 | 01-20-2007 06:55 PM |
| Hinge mortising bit and straight bit. | -Sam- | General Routing | 1 | 03-29-2006 11:58 AM |
