Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools.
Thread Tools Display Modes
Old 02-14-2005, 01:03 PM   #1
Billzhere
New Member
Billzhere is on a distinguished road
Default Newbie Question
I've just started getting back into woodworking after a layoff of way too many years and I have a question for those of you who have been active for a while. What do you use to clean the protective coating off of new router bits or saw blades? I've purchase numerous bits and a few blades lately that came with this plastic like coating on them, and I have no idea how to address the issue. Any help would be appreciated.
Billzhere is offline   Top - Reply with Quote
Old 02-14-2005, 01:28 PM   #2
reds_21
Forum Fanatic
reds_21's Avatar
reds_21 is on a distinguished road
i have too recently asked this same type of question. what i did was just peel it off. or you could also get a knife and make a small cut in it then it should peel right off. i have also heard that you can run it through some scrap wood and the friction of everything will take it right off. but i did the cut and peel option and it worked just fine
reds_21 is offline   Top - Reply with Quote
Old 02-14-2005, 01:32 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Good answer Reds!
Old 02-14-2005, 01:49 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Billzhere:
I usually just cut it with a utility knife and it peels right off. The put some oil lubricant
on the blades and bits, and then the plastic stuff, so it peels real easy. Try not to hit
the carbide cutting edges with the knie though, it's not good for them..
Hope this helps Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 02-14-2005, 03:08 PM   #5
Billzhere
New Member
Thanks for your input everyone, I really appreciate it!
Newbie question re: plunge router Chris_Barry Table-mounted Routing 1 02-11-2008 05:46 PM
Dadoes - newbie question Drick Starting Off 8 05-09-2006 02:00 AM
Newbie Question on Routing jig-tables Cookie199 General Routing 2 02-19-2006 07:47 PM
newbie question falcn63 Table-mounted Routing 1 01-24-2006 10:23 PM
Newbie question on router mounting WallyB Table-mounted Routing 5 06-06-2005 09:20 AM
