Rate This Thread - Bench dog holes.
Thread Tools Display Modes
Old 02-16-2005, 06:09 AM   #1
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Question Bench dog holes
I will be assembling my benchtop this weekend (base is now complete) and need advise on routing square bench dog holes along the front and side edges before adding the final edging around the ends (2x6 material). I will be laminating 2 solid wood doors together 1 3/4 inches thick each and facing the the top door with hard wood.
My question is, since this top will be quite heavy and will need to be stood on end to make the square holes, what would be your thoughts on hand routing these rascals. I cannot think of a way to secure a guide fence or some type of device to keep things straight. Also wondering how to secure the door on end while I make the cuts. What about tearout on the outfeed, should I clamp a sacraficial scrap to the exit end?
Any thoughts or advice to help a newbie will be much appreciated.
Cheers,
Bob
Pictures from the shop
http://s107.photobucket.com/albums/m292/bnoles616/
Bob is offline   Top - Reply with Quote
Old 02-16-2005, 09:20 AM   #2
jerrymayfield
Forum Geek
i don't understand why the top would have to be stood on its edge. please explain
regards
jerry
Old 02-16-2005, 10:30 AM   #3
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Jerry,
I guess my thinking is that it would keep me from routing thru 4" thick stock and instead would only be working thru maybe 2" instead??????
I'm not sure I have a bit that is 4" long?????
That is why I am asking for ideas..... I'm a NEWBIE !
Cheers,
Bob
Old 02-16-2005, 03:39 PM   #4
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi BobN:
that bench top will be plenty thick, i would go for a single solid door, with hard wood on the top. However, you could make a template of the square holes that you need.
That will allow you to do them with the top in the horizontal position. A plunge route will a long spiral bit might do it. The template requires that you make the template
hole larger, based on the difference between the size of the bit you use and the
size (outside diameter) of the guide bush.
Hope this helps.. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 02-16-2005, 03:39 PM   #5
Exboss
Jr. Member
Exboss is on a distinguished road
Default Bench Dog holes
Originally Posted by Bob N
Jerry,
Take a piece of 1/4" plywood and make a jig. Pick a bushing and spiral bit and figure what size hole must be cut in the jig to get the proper dog hole. Use a plunge router and go to town. You can either double stick tape your jig to the door or tack it with brads. Bob and Rick make jigs all the time. Do one door at a time.
Good luck
Exboss is offline   Top - Reply with Quote
Old 02-16-2005, 05:24 PM   #6
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Hey guys.... thanks so much for your helpful advice. I believe the light bulb is starting to burn now. Sometimes you can get stuck just trying to think something thru. I think with the tips offered, I can tackle this beast and tame it.
Best to each of you.
Cheers,
Bob
Old 02-17-2005, 08:59 AM   #7
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Bob, my turn to ask a silly question. You are building this from a kit or just a set of plans? Is the top already laminated together? I hope you respond to this before applying glue.
Old 02-17-2005, 10:12 AM   #8
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Mike,
No, I am constructing this from scratch and a head full of crazy ideas. I want it BIG and I want it STRONG and I want it SOLID.
I have not applied glue yet. I was going to pick up 2 solid wood doors Friday afternoon and work the top up this weekend. They are 1 3/4" thick and 32X81" in size wieghing in at over 60lbs each . I was planning on gluing all of this up with Titebond II and then making my dog holes before facing with oak trim.
Am I about to make a fatal error? If so please stop me and change my path good friend.
Thanks,
Cheers,
Bob
Old 02-17-2005, 11:14 AM   #9
Senior Moderator
Supreme Forum King
Since you are glueing up your top all you need to do is cut dado's in 2 of your boards before glue is applied. When you assemble your boards you will have perfect precut squares. (As I look at this I realize I should of said to rip the doors at the locations you want your dog holes) I would also suggest using Titebond III if you have it. The extra working time is nice on larger projects, and it is the strongest of the Titebond glues.
Old 02-17-2005, 10:25 PM   #10
reible
Supreme Forum King
reible's Avatar
This sure sounds like the way to go. I should point out a couple of things......
1) Some bench dogs require a hole with a pitch to it (for some reason 12 degs sounds right) so if you have not picked out the ones you are going to use that should be done before you make the holes.
2) If you have the vice(s) picked out they may change the way you do things so if you don't have those yet you might want to hold off until you do.
3) If the bench is still toooo light and if you have a dual support across the bottom go to garage sales and get the weight sets that are always on sale with the bar and loose weights. That way you can add 110 pounds easy and the free weights work for glue jobs etc.
Ed
Bench for Router Table mcelduff Table-mounted Routing 3 02-20-2008 12:48 PM
Bench Dog Advice needed LonePalm Table-mounted Routing 1 01-13-2008 01:49 PM
Shelf pin hole jig - reviews and router solution Greg_R Jigs and Fixtures 7 12-30-2007 06:18 PM
Bench Dog Files Chapter 11 Bankruptcy jennofarc Tools and Woodworking 12 11-18-2007 03:08 PM
Bench sized powertools JTsteelblu Tools and Woodworking 3 10-13-2004 01:31 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
