The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page double stick tape
double stick tape
Tools and Woodworking Discuss double stick tape in the General Woodworking forums; I went shopping for double stick tape and they had two types. One of them was double stck scoth tape ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 02-16-2005, 10:54 PM   #1
trap
Forum Fanatic
trap's Avatar
User Info
Trader Rating: (0)
Gallery: View
trap has a spectacular aura abouttrap has a spectacular aura about
Question double stick tape
Send Private Message | View Profile
I went shopping for double stick tape and they had two types. One of them was double stck scoth tape and the other looked like it was about a 1/16 inch thick. Which would bw best for woodworking projects, or is thereanother type I am unaware of?
Bud
trap is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 02-17-2005, 03:07 AM   #2
Kevin
Forum Administrator
Forum Fanatic
Kevin's Avatar
User Info
Trader Rating: (0)
Gallery: View
Kevin will become famous soon enough
I'm pretty sure that the dubble stick tabe comes in a range of widths, I'm not to sure on this tho.
Kevin is online now   Top | Reply with Quote |
Old 02-17-2005, 06:00 AM   #3
ejant
Router King
Supreme Forum King
ejant's Avatar
User Info
Trader Rating: (0)
Gallery: View
ejant will become famous soon enough
I prefer the plastic carpet type double stick tape. Very strong hold.
ejant is offline   Top | Reply with Quote |
Old 02-17-2005, 09:02 AM   #4
Senior Moderator
Supreme Forum King
User Info
Trader Rating: (0)
Gallery: View
Country: Detroit, Michigan USA
Mike has disabled reputation
Bud, find the cheapest carpet tape you can. Its just going in the trash after it's short job. The double sided Scotch tape wont work except on the very lightest of jobs.
Mike is offline   Top | Reply with Quote |
Old 02-17-2005, 10:31 AM   #5
reible
Supreme Forum King
reible's Avatar
User Info
Trader Rating: (0)
Gallery: View
I would say go to a store that sells the tape that is used for lathe turning.
It is pressure sensitive so you have to use force to press it down.... It peels off of without a lot effort which will not happen if you happen to get a paper backed one.... I got a roll this paper stuff by mistake one time.... I still have it but never use it because of the effort it takes to peel off.
No not get double stick foam tape..... often about 1/16" thick, you will spend more time getting the mess off then woodworking.
Carpet tape I've tried but didn't like, it never seem to hold as well as I like but that is maybe just me??????
The last roll I got was about $10 for a 1" wide..... sorry I don't recall the length..... This tape does hold very well and you don't need to use as much of it as would with say carpet tape.
Ed
reible is offline   Top | Reply with Quote |
Old 02-17-2005, 11:39 AM   #6
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
User Info
Trader Rating: (1)
Gallery: View
Check out the link for Tesa tape. I use 4970 double stick tape, check the link
Rick and Bob
The Router Guys
BobandRick is offline   Top | Reply with Quote |
Old 02-17-2005, 12:58 PM   #7
trap
Forum Fanatic
trap's Avatar
User Info
Trader Rating: (0)
Gallery: View
spent over an hour on the net looking for it. All sites are UK or PDF information.
I guess it is not available in US
Old 02-17-2005, 01:59 PM   #8
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
User Info
Trader Rating: (1)
Gallery: View
Check with these guys...Link
Rick and Bob
The Router Guys
double stick tape
Search this Thread:
Advanced Search
I want Ricks push stick!! Birchwood General Routing 23 05-09-2008 11:47 PM
Double Sided Tape? Router is still my name Portable Routing 7 05-04-2006 06:00 PM
double sided tape? falcn63 General Routing 4 01-17-2006 01:48 PM
reading a tape measure crafty Dale Table-mounted Routing 7 11-19-2005 11:54 AM
Brads VS. Double Sided Tape Pop_pop1 Jigs and Fixtures 8 08-18-2005 05:11 AM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
