| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User Forum Fanatic | Hi Guys I hadn't been in my shop for some time and when I pulled some of my router bits out of their storage tray I noted a lot of rust on their shanks. I can probably clean the rust off, and hopefully it will not effect the performance of the bits much. The rust evedently was caused because my bit tray is made of unfinished Birch Plywood. The wood apparently absorbed moisture and caused the bits to rust while being stored. I would suggest to everyone to either finish their bit tray holes, make the tray out of UHMW or some other kind of non absorbant material, or store their bits somewhere other than in an unfinished tray when not in use.
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| | #2 |
| Forum Administrator Forum Fanatic | Thanks for the tip. That is somthing that you don't think about untill the time comes to use your bits again. That is a really good thing to keep in mind. Thanks!! |
| | #3 |
| Registered User Forum Fanatic | This is why sets of router cuters always have plastic inserts to hold the cutters. Even sets in wooden boxes have plastic inserts. It's worth getting some plastic tubing with an inner diameter a little bigger than the cutter shank and drill holes in your plywood to take short lengths of this tubing.
__________________ Dewy support team at Paltalk voice chat program |
| Already Problems | neuschu | Introductions | 7 | 01-22-2008 11:32 PM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
