| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Registered User New Member | I would like to remove the wood panels from my kitchen cabinets and insert 1/8" glass. Is there a router bit that would help me with this? Thank you, wakedaddy |
| | #2 |
| The Router Guys Forum King | What tools do you have? How many different sizes of doors? I would use a Portable router, a straight bit, template guide and a stick pattern but let me know what you have and how many sizes and then I will detail the procedure.
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. |
| | #3 |
| Registered User New Member | 8 Doors. Cut out 9.75 x 19.75. Need additional 1/8" inset all the way around for glass. Thank you |
| | #4 | |
| Retired Moderator Forum King | Quote:
I'm glad you asked this question. I'm looking forward to a project like this in the future and getting extra info would be nice especially from BobandRick! Looking forward for the reply. Boricua ![]() | |
| | #5 |
| Senior Moderator Supreme Forum King | Wakedaddy, 1/8" on each edge is not enough support for glass unless you intend to epoxy it in place. Since cabinet doors tend to get slammed a lot I would allow at least 1/4" on each side and would prefer 3/8" so that a sturdy keeper strip could be easily affixed.
__________________ Mike |
| | #6 |
| Registered User Forum Geek | Hi: I believe 1/8th glass is the thickness and if so, I would use a rabiting bit and take about 3/8ths X 3/8ths cut. This will allow some extra glass, about 5/16ths around the perimeter. It will leave room for a small quarter round onthe back of the doors. Cutting the rabit in the doorsfirst will allow accurate measurements to be taken prior to cutting the glass. Hope this helps.. Woodnut65 |
| | #7 |
| Registered User New Member | Thank you all for your information. I has been very helpful. I feel much more confident about doing this now. You Rock! |
| | #8 | |
| The Router Guys Forum King | Quote:
To begin with we can't use a rabbeting bit to remove the material in the back of the panel door... why? because the panel is in the way. First thing we have to get the panel out of the door, so we can make a 1/4" thick plywood pattern that is the same size as the panel in the existing door. It is usually 3/8" to 1/2" larger than the inside edge on the back...if you need more let me know. Once we have the pattern made we use double stick tape to position and mount the pattern on the back of the panel door. Next we want to set the depth of the straight bit to match the thickness of the material holding the panel in on the back side of the door. Using the straight bit and template guide cut out the material on the back side of the panel door and remove the panel from the stile and rail of the door. We now have a frame of the door ready to receive the glass. Measure the exact size of the opening from the back side and get the glass to match. You might want to go to the glass cutter with your door and let them measure and cut the glass for the doors. Use silicon to seal in the glass into the door frames. Hope this was helpful, if you need more info like photos let me know, Rick
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #9 |
| Registered User New Member | Would appreciate pictures. I don`t understand,you say we have to first get the panel out of the frame to make a pattern, then to use the pattern to remove the panel from the stiles & rails of the door. I will cut & paste this below. First thing we have to get the panel out of the door, so we can make a 1/4" thick plywood pattern Using the straight bit and template guide cut out the material on the back side of the panel door and remove the panel from the stile and rail of the door. How do you use a pattern to cut a hole the same size as the pattern??? or am I missing something???Garth |
| | #10 |
| Forum Contributer Supreme Forum King | I know this is a old post but I see alot of people viewing it. This is what I would do. Because the panel should be floating in the frame (not glued in place) ,take it to the scholl saw/jig saw and cut the panel out then use a rabbit bit and remove the inside lip on the door frame then take a SHARP chisel and sq. the inside corners at that point you can make munt-ins and mullion's or just use a one glass panel or stained glass panel, (stained glass panels are easy to make now days with all the kits out on the market) ![]() I use the extra thick super glue with spray activator to put the munt-ins and mullion's in place if the frame is glued up with one glass panel in this way you will get the look of many glass panels. Note***munt-ins and mullion's can be tricky to make on the router table but if you use the male and female jig way it's easy but you will need to remove a small part on the back side of the munt-ins and mullion's if you use one glass panel. http://www.woodshopdemos.com/smfld-77.jpg http://www.woodshopdemos.com/gclk-8.htm Hope this helps some one ![]() Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 10-19-2006 at 10:11 AM. |
| Kitchen cabinet make over (new doors / drawers) | Nickbee | Show N' Tell | 11 | 11-13-2008 06:26 PM |
| Reproducing a panel moulding on existing doors | paulcomi | Table-mounted Routing | 3 | 06-29-2007 01:35 PM |
| Glass Panel Doors Bit set | Stu in Tokyo Japan | Table-mounted Routing | 2 | 11-27-2005 10:24 AM |
| Glass for cabinet question? | hammernail | General Routing | 3 | 08-31-2005 12:30 AM |
| kitchen cabinet doors help | puretrick | Tools and Woodworking | 15 | 06-05-2005 05:28 PM |
