| Tools and Woodworking Mainly for general woodworking questions and comments you may also come here to ask questions, get advice and share your experience with power tools. |
| | #1 |
| Retired Moderator Forum King | Hi everyone, I want to "picture frame" a bathroom mirror that is 30"x35" in size with 1x2 furring strips that I will rout a decorative edge to. My question is, which nails are best to use to hang up the frame? I was thinking of using 4d nails which I already have on hand. I will definitely pre-drill the nail holes first before installing them, that way the frame won't crack on me. Thanks! ![]() Boricua ![]() Last edited by -Sam-; 03-15-2005 at 02:02 PM. |
| | #2 | |
Ed | |
| | #3 |
| Retired Moderator Forum King | reible, Yes nails! What's wrong with nails? Okay, okay, you're probably thinking use a nail gun and/or a little construction adhesive right? Hmmm... ![]() |
| | #4 |
| Registered User Forum King | Nailing furring strips used to be pretty common in construction - where exactly are you hanging this mirror? Basement, garage, shed? ![]()
__________________ Reunite Gondwanaland |
| | #5 |
| Senior Moderator Supreme Forum King | Have you considered using a key hole bit to rout slots in the back side of the furring strips? I would use 6 holes for this size frame to ensure good support, 2 on each side and the bottom. There are many good types of wall anchors that will accept screws. Yes, this costs a bit more than the nails but it will look far superior.
__________________ Mike |
| | #6 | |
Ed | |
| | #7 | |
| Retired Moderator Forum King | Quote:
Okay, let me go and start thinking... Hmmm....Last edited by -Sam-; 03-16-2005 at 01:43 PM. | |
| | #8 |
| Registered User Supreme Forum King | Here is another idea, something I did for another project but it might give you another idea. I took one of those hanger bolts (half screw, half bolt I think it might have been #8), drilled the "frame", marked the holes on the wall, drill a starter hole and screwed the wood screw part in to the wall. Put the "frame" up and used some fancy drawer pulls I picked up at on sale at the hardware store..... I only had two left, and I only needed two so this worked out nicely. The wife likes to hang necklaces or whatever on the pulls.... or maybe if you get bigger pulls you could hang ear protection and safety glasses, or neck ties????? The pulls I had had a threaded insert and that determined the fastener size but I recall having problems finding the right length in that small dia. Oh well just another idea. Ed |
| | #9 |
| Retired Moderator Forum King | Wow, that's a pretty good idea too reible, thanks! ![]() |
| | #10 |
| Registered User Dedicated Member | One thing to keep in mind, Not sure if you are painting or staining the frame, but if you are, rember the inside the dado/rabit where the mirror is sitting. I didn't do this to mine and as the mirror "Reflects" what it sees, you can see the "unstained" wood in the reflection. oops. |
| Framing a small piece of wood | lea6141 | Table-mounted Routing | 9 | 01-26-2008 10:29 PM |
| Introduction Forum | Antonio E. Erlano | Introductions | 36 | 01-21-2008 12:27 PM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| Pediment mirror plan | Ebenister | Tools and Woodworking | 4 | 02-18-2005 02:32 PM |
