How many router bits do you own? - Page 3 - Router Forums
View Poll Results: How many router bits do you own?
0 to 20 43 25.00%
21 to 50 61 35.47%
51 to 80 33 19.19%
81 to 110 12 6.98%
111 to 150 9 5.23%
over 151 14 8.14%
Voters: 172. You may not vote on this poll
 1Likes
post #21 of 29 (permalink) Old 02-14-2015, 09:44 AM
mftha's Avatar
It seems every project I plan requires at least one bit I don't have. I started with a boxed set of 1/4 inch shank bits my now ex-wife bought for me, then watching the Router Workshop I learned the value of the flush trim bit and one of those was my first addition. Then I bought a router with 1/2 inch collet, and things exploded from there!
The boxed set included round overs, coves, straight, a dovetail and a panel pilot bit. I still have not figured out what the panel pilot bit is for.
"Teach your children what we have taught ours, that the earth is our mother. Whatever befalls the earth befalls the sons of the earth. The earth does not belong to man; man belongs to the earth. Man did not weave the web of life; he is merely a strand in it. We do not inherit the earth from our ancestors; we borrow it from our children."
-attributed to Chief Seattle of the Native American Suquamish Tribe
  • Wood working, especially router work is too much fun to let "disabilities" get in the way.
  • see MEBCWD's signature line; be certain brain is properly powered up and engaged
mftha is online now
post #22 of 29 (permalink) Old 02-14-2015, 01:32 PM
kp91's Avatar
First Name: Doug
The panel pilot bit is for punching holes in drywall or panelling. If you roughly know where the box is buried behind the wall, you can plunge into it, the bit will ride on the inside edge and cut the box out.
Unfortunately, if they are the cheap, plastic boxes, the box will shift a little as you cut it and you can get an oversize hole on the far end.
I prefer my dremel oscillating saw for cutting these openings. Less dust, easier cleanup.
1 John 1:9
Fredericksburg, VA
My daughter amazes me https://houndsathazelwild.wordpress....houndgold2016/
kp91 is online now
post #23 of 29 (permalink) Old 02-14-2015, 01:50 PM
N'awlins77's Avatar
First Name: Lee
My first reply and tally was in '12. I'm sure I can bump my number up by at least 30% today!
N'awlins77 is offline
post #24 of 29 (permalink) Old 02-15-2015, 12:58 AM
mftha's Avatar
Thanks very much Doug. I have never needed to do what you describe, but it seems like the Dremel saw is better suited.
mftha is online now
post #25 of 29 (permalink) Old 02-15-2015, 01:00 AM
mftha's Avatar
I was certain I had replied years ago but it let me vote again, and my current count is much higher than it was then. Now I ned to show that I use them!
mftha is online now
post #26 of 29 (permalink) Old 02-15-2015, 08:50 AM
N'awlins77's Avatar
First Name: Lee
Yea, wouldn't let me vote again. But I looked back at a pic I took, I had 49 back then, now I have 68 (new pic). I still have about 8 of them in their original protective rust preservative. Those I bought on sales or clearance racks.
Name:	152-Router Bits 2015.jpg
post #27 of 29 (permalink) Old 02-16-2015, 11:23 AM
DonkeyHody's Avatar
First Name: Andy
Originally Posted by reible View Post
I was just thinking about a new method of storage for my router bits. One of the first things I needed to know was how many I have. It was a lot more then I would have guessed...... Now this count is both 1/4" and 1/2" bits that would take up a place in a storage area with an associated hole for it to set in. So if you have (3) 1/4" straight bit that counts as 3 bits.... if you have set of bearings that change the profile of the bit 7 different ways it is still one bit for this count.
No prizes for the most or least but if you would like to tell us how you store them that would be great.
I counted 51 router bits. Years ago, I built a small chest to keep them in from leftover scraps of walnut and cherry . It has a removable tray that rests in the top of the box while I access the second level of bits in the bottom. It has worked out very well, but I'm outgrowing it and may move the bits to a drawer under my workbench. Photos Attached.
Name:	Bottom Storage.jpg
DonkeyHody is online now
post #28 of 29 (permalink) Old 04-22-2015, 02:35 PM
First Name: David
How come "I've lost count" or "I don't have enough fingers to count that high" weren't voting options? I am guessing I am at about 85. Some are duplicates though.
thedavel is offline
post #29 of 29 (permalink) Old 03-31-2016, 04:14 PM
BobbyLee's Avatar
First Name: BobbyLee
79 so far. Set of 74 - 2 profile bits - 1 sc-50 carving bit - 1 60 degree v groove - 1 90 degree v groove - plus an extension collet. Will eventually replace my most usable ones with better brands as time and finances permit.
A piece of wood a day; Helps keep the ill troubles of life away..
BobbyLee is offline
Human Verification
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 14 05-23-2012 05:51 PM
New Router my way reible General Routing 20 11-30-2011 12:18 PM
Already Problems neuschu Introductions 11 12-15-2009 08:01 AM
