Go Back   Router Forums > Other > Lobby > The Voting Booth
The Voting Booth Post polls and vote!
View Poll Results: Favorite Router Manufacturer
Dewalt 37 10.11%
Porter Cable 154 42.08%
Bosch 49 13.39%
Freud 16 4.37%
Milwaukee 7 1.91%
Fein 0 0%
Makita 7 1.91%
Triton 16 4.37%
Craftsman 21 5.74%
Hitachi 33 9.02%
Other (specify) 26 7.10%
Voters: 366. You may not vote on this poll
Thread Closed
Thread Tools Display Modes
Old 03-28-2005, 03:56 AM   #31
chappo
New Member
chappo's Avatar
chappo is on a distinguished road
In Australia we have a range of budget tools (GMC http://www.gmcompany.com/ ) designed in Australia, manufactured in China.
They have an interesting range of routers. The one I chose is the 1550 Kit
It comprises the plunge router (1550 W - 2 HP), side fence, template bush and 50 bits all in a custom kit case.
My choice was governed partly by budget (cost was $159 Australian), and partly by this being my first router - a tool that I didn't know how much use it would get.
The router is well made, has 1/4" and 1/2" collets, electronic variable speed, plunges to 42mm and has a rack and pinion depth gauge with micrometer.
Needless to say, I have now found it to be the most versatile tool in my workshop - and a two year guarantee is pretty good too!
chappo is offline   Top -
Old 03-28-2005, 07:05 PM   #32
RonP
RonP is on a distinguished road
I have two Craftsman and a Porter Cable. I use the PC most because it is on my router table but I have had trouble with the switch ever since it was new( about 4-5 years). I took it back for repairs several time but as soon as I turned it up side on the table the switch would not make good contact using the switch lock. I finally gave up and wrapped a strap around the trigger to keep it "on" permanently and use the table switch.
The service people in Charlotte weren't any help either and rude also. The guy, Craige ( I remember well) would only say "we recommend that you read the owner's manual"
I probably wil not buy another Porter Cable anything.
RonP is offline   Top -
Old 03-28-2005, 08:40 PM   #33
krislu
New Member
krislu is on a distinguished road
Originally Posted by cabinetsetc
I have a 1617 bosch and had the same problem with the bits sticking in the router (I mean really sticking) I've ruined bits trying to get it to give them back. I changed the collet and solved the problem. Rick
Rick- Thanks but I replaced the collet with a new one and the bits still stick. I ruined a few bits (trying to get them out) also. - Kris
- Kris
krislu is offline   Top -
Old 03-30-2005, 12:23 AM   #34
charis
New Member
charis is on a distinguished road
Dewakt
charis is offline   Top -
Old 03-30-2005, 10:56 AM   #35
geffre
New Member
geffre is on a distinguished road
Default Do not have a favorite
[quote=ejant]Who is your preferred router manufacturer
I have a an older Craftsman, which was a gift. It works but I would much prefer one that can use both 1/4 and 1/2 inch bits.
geffre is offline   Top -
Old 04-03-2005, 02:41 PM   #36
moreorles2000
Dedicated Member
moreorles2000's Avatar
First Name: les
moreorles2000 is on a distinguished road
first post
but i purchased a porter cable last year and have not made anything yet. ibought it because i figured to buy something of reasonable quality so it would last .hopefully this summer i will put it to use. this is my very first router and i am trying to learn.
moreorles2000 is offline   Top -
Old 04-03-2005, 04:39 PM   #37
reible
Supreme Forum King
reible's Avatar
I'm sorry to hear your having swith problems. The couple of PC I have use a toggle switch but it sounds like you have another model.
Anyway what I wanted to mention is that I have a large Craftsman router mounted in a table and it too has switch problems..... wood dust gets in because of it being mounted upside down and I have to take it out now and again and take the handle apart and clean it out. After several years of this a cleaning did not seem to help, it still would turn on when you pulled the trigger but when you pushed the button to lock it on it would turn off. In other words it would not stay running without you holding the trigger.
I took it back apart and found that they had used some little square of foam tape to take up the space between between you holding the trigger and the button holding the trigger. The foam had flatten so much that it no longer work. I pulled it off and cut a little chunk new foam tape and it's working again.
I guess what I'm saying is maybe taking a little look around at the problem yourself will allow you can come up with a solution without having to deal with less then helpful repair people.
Ed
reible is offline   Top -
Old 04-10-2005, 01:04 AM   #38
retsgt
New Member
retsgt's Avatar
retsgt is on a distinguished road
Send a message via Yahoo to retsgt
I just picked up a new PC. Had a circa 1977 Black and Decker like comparing a Pinto and a Porche
Every day is a good woodworking day!!
retsgt is offline   Top -
Old 11-27-2005, 07:57 PM   #39
eyewoodnt
eyewoodnt's Avatar
eyewoodnt is on a distinguished road
I have my original PC 690's with all three bases, and 3 Hitachi MV12's. I really like the power the Hitachi's have and with some mod's I got from John at www.woodshopdemos.com
I put one in my router table, and the oter two in dedicated jigs. I also have the professional PC laminate trimmer and use this for edge profiling and sign making. PC are great, Hitachi's are brutes.
"Be yourself, everybody else is taken."
eyewoodnt is offline   Top -
Old 12-07-2005, 11:36 PM   #40
RBA
New Member
RBA is on a distinguished road
Received it as a gift a brand called Yukon?
Seems to be a good working unit so far.
Plunge Router
2 1/8 hp
variable speed 11,500 - 28,000 rpm
Push button Locking pin for shaft (Not a swing over lever like craftman)
Has anyone heard of this brand?
RBA is offline   Top -
Thread Closed
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
