| | #1 |
| Registered User Sr. Member | A thread here last week got me to thinking about my cheap little Craftsman scroll saw. It is Mod #137216-100. I can get it to cut okay most of the time, but I believe it might be missing a part, as another fella's saw was. I DO know that the goofy little "hold down" attachment is a joke! Can anybody show me or tell me where to find a photo of the area right around and just below the blade on this model saw? I was running into the same "chattering" problem some other guys experienced, but was able to pretty much overcome or work around it. But I NOW suspect I know WHY the problem exists. I bought the saw, like new, for $16 on Ebay. Maybe NOW I know why the guy sold it so new and so soon! HA! ![]() |
| | #2 |
| Retired Moderator Supreme Forum King | See if this helps birch. This is from the Craftsman Web Page: See the info below plus this is the parts page link and then enter the model number: 137216-100 in the search and you will get the info and diagram shown below. If you don't have a manual for it use the help button and tell them you need a manual for this model and ask them to email you a pdf of it or something. http://www3.sears.com/ Diagram http://www3.sears.com/Paul/Leadimage...titleID=00001& Parts List BASE 19A00101 1 FOOT (3) 16200301 2 WING NUT 19A00301 3 LEVELING PAD 19A00401 4 HEX HD. BOLT (5) (M6 X 1.0-30) 2601BBDA43 5 FLAT WASHER (5) (GAUGE 6 X 18-1.5) 2601MBDN31 6 BRACKET-TILT 19A05001 7 HEX SOCKET HD. CAP SCREW (2) (M6 X 1.0-16) 2617BBLB21 8 TRUNNION BRACKET 19A05201 9 TILTING SCALE 19A05301 10 CR. RE. PAN HD. SCREW (3) (M5 X 0.8-16) 2668BBDA25 11 HEX. SOC. HD. CAP BOLT (M8 X 1.25-40) 2602BBLA59 12 TRADE MARK LABEL 19A05601 13 TABLE 19A05701 14 INSERT 11A02501 15 HOUSING RIGHT 19A10001 16 CLAMP CORD (4) 19A10101 17 CR. RE. PAN HD. SCREW (4) / CR. RE. TRUSS HD. TAPPING (M5 X 0.8-10) 2668BBDA32 18 SCREW (M4 X 16-16) 2653MZDE14 19 EXTERNAL TOOTH LOCK WASHER (GAUGE 4) 2504MZC004 20 NUT CHUCK (M6 X 1.0 T=6) 2705FBD106 21 HEX SOC. HD. CAP SCREW (2) (M6 X 1.0-20) 2617BBLB22 22 PLUNGER HOUSING 19A10701 23 FLAT WASHER (GAUGE 6 X 18-1.5) 2501MBDN31 24 SHAFT PIVOT 19A10901 25 MOTOR 8586C28926 26 ECCENTRIC ASSEMBLY 19A12202A1 27 WASHER 14701101 28 NUT CHUCK (M5 X 0.8 T = 5) 2705FBD105 29 BEARING SEAT ASSEMBLY 19A12601A1 30 BUSH (2) 19A13101 31 HEX SOC. HD. CAP BOLT (M5 X 0.8 - 35) 2602BBLB30 32 POINTER 19A14001 33 CR. RE. PAN HD. SCREW (M5 X 0.8-12) 2568BBDA24 34 HEX SOC. SET SCREW (M8 X 1.25-8) 2603BDLA52 35 SPRING 13108501 36 STEEL BALL 2983AL5010 37 PLUNGER HANDLE 11A00101 38 FLAT WASHER (GAUGE 6 X 18 - 1.5) 2501MBDN31 39 COMPRESSION SPRING 14403301 40 TENSION HANDLE 11A00401 41 CAUTION LABEL 11A03401 42 WAVE WASHER 2506MBN608 43 NUT CHUCK (M8 X 1.25 T=8) 2705FBD108 44 HEX SOC. HD. CAP SCREWS (3) (M6 X 1.0-16) 2617BBLC21 45 LABEL 10216715 46 RETAINING RING 18515401 47 CR.RE. PAN HD. SCREW (M4 X 0.7-6) 2666BBDA06 48 BELLOWS 16721602 50 PLUG HOUSING 16721902 51 CR. RE. COUNT HD. SCREW (2) (M5*0.8-12) 2636BBDA24 52 PVC HOSE 16730001 53 AIR DUCT ASSEMBLY 16730102A1 54 HOUSING 19A20001 55 CR. RE. PAN HD. SCREW (4) (M5 X 0.8-50) 2668BBD894 56 CR.RE. PAN HD. SCREW (2) (M5 X 0.8-10) 2668BBDA32 57 BLADE BOX 19A20301 58 CR. RE. PAN HD. SCREW (2) (M5X0.8-20) 2668BBDA27 59 DUST SHIELD (4) 18402702 60 CR. RE. TRUSS HD. SCREW (2) (M5 X 0.8-8) 2637BBDA23 61 SUPPORT ROD 19A20701 62 HEX. SOC. SET SCREW (2) (M6 X 1.0-7) 2603BBLA36 63 PLUNGER HOUSING 11A10701 64 CLAMP PLATE 109A20P1 65 LABEL 19A21101 66 TRADE-MARK LABEL (2) 19A21201 67 PLATE COVER 19A21801 68 CLAMP HANDLE 11A11001 69 QUICK RELEASE ASSEMBLY 19A25801A1 70 HEX SOC. HD. CAP BOLT (2) (M4 X 0.7-10) 2602BBLA08 71 SPRING WASHER (2) 2502ABC401 72 SET PLATE (2) 14706601 73 UPPER ARM ROCKER ASSEMBLY CR. RE. PAN HD. ROUND NECK 16704201A1 74 SCREW (2) (M4 X 0.7-7.5) 2676BBDAA3 75 EXTENSSION SPRING 18102001 76 BOTTOM ARM ROCKER 19A26701 77 BEARING SEAT 15802301 78 N/A N/P 79 BLADE 15802103 80 BLADE 15802104 81 HOLDER BLADE ASSEMBLY (2) 17104404A3 82A BOLT CLAMP (2) 19610202 83 N/A N/P 84 N/A N/P 85 N/A N/P 86 CONNECTOR BOX 19A31001 87 CR. RE. TRUSS HD. SCREW (M4 X 0.7-16) 2637BBDA10 88 CONTROLLER ASSEMBLY 19A31201A1 89 SPEED POTENT 26S9 89A CR. RE. PAN HD. TAPPING SCREW (4) (M3 X 24-6) 2660MBCE01 90 CONNECTOR BOX COVER 19A31401 91 CR. RE. PAN HD. TAPPING SCREW (4) (M4 X 10-25) 2660PBCK23 92 CIRCUIT BREAKER SWITCH 2853D55714 93 STRAIN RELIEF 2801UBHA07 94 WRENCH HEX 2136MBL703 95 LEAD WIRE ASSEMBLY 28065558AL 96 POWER CABLE 2807BB08HB 97 SWITCH BOX 19A35001 98 CR. RE. PAN HD. SCREW (3) (M5 X 0.8-20) 2668BBDA27 99 LINKAGE BAR 0ZWS None SWITCH BOX COVER 19A35202 100 ROCKER SWITCH 2852U55721 101 CR. RE. PAN HD. SCREW (2) (M5 X 16-35) 2660PBCK30 102 PUSH BUTTON 19A35501 103 INDICATED BUTTON 11A25901 104 WAVE WASHER 2506MBN606 105
__________________ My Carving Website: The Iowa Woodcarver http://iowacarver.tripod.com/ My Shop Website - Woodshop 51503 http://woodshop51503.tripod.com/ Last edited by challagan; 06-12-2007 at 08:50 PM. |
| | #3 | |
| Forum Contributer Supreme Forum King | Hi Birch This may help. see below ---------------- Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 11-17-2007 at 11:21 AM. | |
| | #4 |
| Registered User Sr. Member | Jeeez thanks Bob3. I should be able to do something with the links etc. you provided. Lots of stuff there to check. Appreciate the help. |
| | #5 |
| Forum Contributer Supreme Forum King | You'er Welcome Birch NOTE***the one snapshot that shows how you can make one quick and easy and just by pass SEARS....it can be just about anything you have around the shop just as long it works ![]() --------------
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ |
| | #6 |
| Registered User Forum Fanatic | I actually hesitate to mention this for fear of hurting anyone's feelings, but when I visited a friend's shop and commented that he had the same Craftsman 16" Scroll Saw as mine, he said he "hated it and never uses it because the work chatters and jumps around so badly... too hard to hold it down." When I examined it, I discovered that he had the BLADE UPSIDE DOWN !... teeth pointing up ! I turned the blade over, he tried it out and smiled! That was about ten years ago. He still thanks me occasionally, because he's still getting good service out of it!
__________________ Thinking outside the box? What box? |
| | #7 |
| Official Greeter Supreme Forum King | Roger I had the same kind of deal with a Toolmaker apprentice. She put on a new saw blade just before lunch. She couldn't get it to cut at all. When she went to lunch, I looked at the bade and she had it upside down. I told her to take it off and turn it over and try again. Walla, cuts like a dream. I don't think I got any thanks.
__________________ Dave the "Doctor" In woodworking there is no scrap, only firewood. |
| dust extraction for craftsman routers | mjmpropman | General Routing | 0 | 04-23-2008 11:11 AM |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 08:54 AM |
| Help identify scroll saw & Band saw | Kristin D | Tools and Woodworking | 11 | 11-29-2007 09:11 PM |
| Porter Cable vs. Craftsman | rprice54 | Tools and Woodworking | 7 | 01-17-2006 10:16 PM |
| Need Craftsman part | Birchwood | Tools and Woodworking | 1 | 05-25-2005 01:18 PM |
