Help
Go Back   Router Forums > General Woodworking > Wood Species
IconIt appears you aren’t a registered member of the Router Forums community. Why not spend less than a minute and register for the largest router and woodworking community on the web! Join in over 20,000 discussions with over 40,000 woodworkers. If you’re an experienced or beginner woodworker, your questions and knowledge is always warmly welcomed by our community. Register now for your FREE account!
Category 1, Best Creative Design:
This is a discussion on Category 1, Best Creative Design: within the Wood Species forums, part of the General Woodworking category; In this category you are free to expand your vision of a simple 5 1/2” ...
LinkBack (3) Thread Tools Display Modes
Old 05-15-2009, 09:15 AM   3 links from elsewhere to this Post. Click to view. #1 (permalink)
The Router Guys
BobandRick's Avatar
Default Category 1, Best Creative Design:
Report Post Report This Post!
In this category you are free to expand your vision of a simple 5 1/2” X 7 1/2” plaque. Add a shelf, wood inlay or maybe inset a metal plaque. Bottom line… add something unique. Post a picture of your finished plaque.
For more information about the Wood Species Contest follow this link.
Rick and Bob
The Router Guys
Well I have just completed my first PDF E-Course, which is 10 embedded lessons from the Router Workshop Video Series. This is a must have PDF that you can get some very good pointers on how to use the router. Get your FREE copy here!
BobandRick is offline
Old 08-31-2009, 11:38 PM   #2 (permalink)
Mike will become famous soon enough
Here is design 1 by Rob (SNRGRAILROAD). After routing the bottom edge Rob hand chiseled the cavities for the badge and patch. Rob then built a form around the wood and applied the plastic mix. After it set he removed the form and started sanding. Once he had the surface polished clear He put a round over edge on the plastic. Rob prefered working with the ash wood over the african mahogany or lyptus. A nice way to display his old badge.
Old 08-31-2009, 11:45 PM   #3 (permalink)
Here is Rob's (SNRGRAILROAD) 2nd effort. This is made from lyptus. Rob drilled 4 holes and used a saber saw to make the internal cut out. All top edges were then rounded over and a stopped cove cut on the bottom to mimic feet at the corners. Next Rob used a rabbeting bit to make the ledge for the photo and backer board to rest on. The shelf is glued and pin nailed in place. The piece was gel stained, lightly sanded and sprayed with clear laquer. The little cars are held in place with CA glue. A nice keep sake to house the photo of Aidan Rob's grandson.
Sponsored Advertisements. Register to disable this advertisement.
Old 08-31-2009, 11:53 PM   #4 (permalink)
Design number 3 by Rob (SNRGRAILROAD). I have no idea how Rob dreamed this one up. I know he started by using Forstner bits for the 4 looped cuts. This african mahogany frame is just sprayed with laquer. Once Rob gets the photo to install I will be sure to add another picture to this post.
LinkBacks (?)
LinkBack to this Thread: http://www.routerforums.com/wood-species/14385-category-1-best-creative-design.html
Posted By For Type Date
2009 May : Routerworkshop.net This thread Refback 05-21-2009 12:38 PM
Router Tips : Routerworkshop.net This thread Refback 05-18-2009 12:39 AM
We have a Wood Species Contest… : Routerworkshop.net This thread Refback 05-15-2009 09:42 AM
Milescraft Design and inlay kit # 1207 StanSR Introductions 9 04-26-2010 04:26 PM
First Box Joints w/a Hart Design Jig Wild Rag Jigs and Fixtures 2 03-23-2009 08:54 AM
Open face tread design jig DAP Introductions 2 07-04-2006 02:59 PM
