Help
Go Back   Router Forums > General Woodworking > Woodturning and Lathes
Spalted Maple Vase
This is a discussion on Spalted Maple Vase within the Woodturning and Lathes forums, part of the General Woodworking category; Looks great Bernie. See you didn't loose your touch. By the way where are the ...
Old 01-11-2009, 04:33 AM   #11 (permalink)
Glenmore's Avatar
First Name: Glenmore
Glenmore has a spectacular aura about
Send a message via Skype™ to Glenmore
Report Post Report This Post!
Looks great Bernie. See you didn't loose your touch. By the way where are the pics of you using that vacuum chuck. huh
Glenmore
Days without wood working are days not worth getting up for.
Glenmore is offline
Old 01-22-2009, 02:03 PM   #12 (permalink)
cncdave's Avatar
First Name: Dave
cncdave is on a distinguished road
Hi Bernie
How long does it take to dry the spalted wood before you can start to turn it
Dave
cncdave is offline
Old 01-22-2009, 10:02 PM   #13 (permalink)
BernieW's Avatar
First Name: Bernie
BernieW will become famous soon enough
Dave I turn my bowls so the wall thickness in 10% of the bowl diameter. 10" bowl or smaller I leave the wall thickness at 3/4" and larger than 10" I leave them 1" thick. I soak my bowls in Denatured Alcohol for about 24 to 72 hrs. I then let the surface dry and wrap them in a brown grocery sack kinda like a present. I cut a opening it the bowl part and lay them upside down on a cooling rack I got from wal-mart for I think $2.50. I also put them in a room about 70 degrees with little to no air flow. I let them set for 2 to 4 weeks and they are dry. I take them back to the lathe, true up the tenon and finish turning them down to the thickness I want them. Normally 1/4" to 3/8" thick. Then I finish them. That is kinda of nutshell of what I do. I have found that without the DNA it will take about a year to dry them. Hope this helps.
Bernie W.
aka Poppa
A bad day of turning is still better than a good day at the office.
BernieW is offline
Old 01-23-2009, 06:26 PM   #14 (permalink)
Darrin's Avatar
First Name: Darrin
Darrin is on a distinguished road
Very good!!! I use the same roughing method and same paper bag method with 6-8 mos drying. That Denatured Alcohol info is very useful as I have never heard it before and will try it on a cherry log Im roughing out tomorrow. Thanks!!!
Darrin is offline
Old 01-23-2009, 10:40 PM   #15 (permalink)
BernieW's Avatar
First Name: Bernie
Your welcome Darrin. I find my turnings are generally dry in about 3 to 4 weeks. I like it because it doesn't take 6 months to a year to dry.
Bernie W.
aka Poppa
BernieW is offline
Old 01-26-2009, 01:57 AM   #16 (permalink)
philland's Avatar
First Name: Phil
philland is on a distinguished road
Hey Bernie,
When you true up the tenon do you put it in Cole Jaws? or how do you do it?
There is nothing like the smell of wood as it is being worked; however, lack of filtration leads to fudgy boogers.
philland is offline
Old 01-26-2009, 09:13 PM   #17 (permalink)
BernieW's Avatar
First Name: Bernie
I started with a donut chuck for couple of years, then cole jaws for about a year and now I use a vacuum chuck most times. I just got it and got it hooked up about 3 months ago. I still use the cole jaws at times.
Bernie W.
aka Poppa
BernieW is offline
Old 01-30-2009, 12:49 AM   #18 (permalink)
philland's Avatar
First Name: Phil
The black lines in the wood are a fungus which has spread in the wood. Once the wood is cut is dies but leaves the black stripping. It can be some beautiful stuff. On green wood there are several ways of which I am not a expert on that you can make wood splat.
Thanks Harry.
I don't think that the fungus dies when the wood is cut. I have turned some wood off of a pile that was from a tree, then the next year I turned another piece that was cut from the piece that I had turned earlier, and the spalt had spread significantly and was much more pronounced in the later turned item.
The fungus is part of the decay process and often the difference between a great piece and a bunch of mush (soft wood that is useful for nothing) is getting the wood up and drying at just the right time.
philland is offline
Old 01-30-2009, 12:54 PM   #19 (permalink)
BernieW's Avatar
First Name: Bernie
Phil I hear ya. I just found out some maple that I had did that very thing. There was more spalting in the later piece I turned. The fungus does die out though when finished I have found.
Bernie W.
aka Poppa
BernieW is offline
Old 02-09-2009, 02:15 PM   #20 (permalink)
2LJunkie is on a distinguished road
Congrats on a very pretty piece Bernie. Well worth the "save" effort...Bill...
2LJunkie is offline
Spalted Maple / Walnut / Walnut Burl Box With Inlay… Nickbee Show N' Tell 17 06-21-2009 07:27 PM
Bud vase Mitch12 Woodturning and Lathes 5 05-13-2008 12:34 AM
Hickory Vase Mitch12 Woodturning and Lathes 10 05-07-2008 12:16 AM
Sycamore Vase Dressed up, Hickory NE Bowl mit-ch Woodturning and Lathes 14 03-23-2008 07:25 PM
Spalted Maple jewelry boxs del schisler Show N' Tell 6 04-17-2007 02:13 AM
