Ornamental Wood Turning - Router Forums
post #1 of 15 (permalink) Old 05-01-2011, 03:21 PM Thread Starter
Country: South Africa
First Name: Gem
I don't know if my intro worked or not. While my dinner is in the oven, I will give a brief overview of my needs.
I have been struggling with the idea of making a router lathe, but one that has a little more functionality than the usual. I would like to make it not only a copy-follower but also give it the ability to turn eccentric forms such as hexagons, octagons and other patterns. I believe the machine in question is a rosette lathe, I saw one in Sweden many years ago, but I would like to make more formal shapes than just the frilly things that seem the norm.
I have the necessary experience and patience to make such a machine, but not a great deal of money.
Does anyone know of any plans or have any suggestions for me?
Thankyou for any help you might suggest! Best wishes, Gemma
gemma.laming is offline
post #2 of 15 (permalink) Old 05-01-2011, 03:39 PM
HI Gemma
If you are good with your hand you can copy the one below it will do all the things you listed..
Legacy Woodworking
Legacy Woodworking
post #3 of 15 (permalink) Old 05-01-2011, 04:29 PM Thread Starter
First Name: Gem
Thanks for your speedy response, Bob.
I have seen the machine you allude to, but when I saw it last I had a lot less money than I do now! There are a few issues with it however, and these are that (1) it doesn't have a facility to do copy following along the length of the turning and (2) there is no possibility to do non-circular machining, which routers seem to me to be the most sensible thing to use for this purpose.
I have tried turning octagons on a rosette lathe, but it is very hard to do and you need razor sharp chisels. I liked the idea of being able to use the rotating tool of a router to achieve the same effect.
Any ideas?
Thanks again for taking the time to reply to my post, Gem
post #4 of 15 (permalink) Old 05-01-2011, 04:40 PM
Hi
The lower end router lathes can copy all day long..octagons are easy on the machine below. both come with a locking indexing head.
You can see many snapshots of the two I have in my uploads
post #5 of 15 (permalink) Old 05-01-2011, 05:10 PM Thread Starter
First Name: Gem
Bob, that's great!!! Thanks for the photos, I have taken the liberty of downloading them, I hope you don't mind.
Can I push the boat out a little further and ask if you have any ideas of how you might manage a circular copying facility - I mean instead of using a (I can't think of quite the right word at the moment, it is eleven o'clock at night here in NL!) dividing head for the octagons, etc, but allowing the head to move after a pattern?
I do like the chuck on your machine, it is very practical. I hope you haven't patented it!
Thanks again, I will be in touch further tomorrow. Gemma
post #6 of 15 (permalink) Old 05-01-2011, 05:15 PM
Is the word you are looking for "An indexing Head"
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #7 of 15 (permalink) Old 05-01-2011, 05:20 PM Thread Starter
First Name: Gem
Thanks, James! I think that is the right term for the tool. Gem
post #8 of 15 (permalink) Old 05-01-2011, 05:46 PM
Hi
The router can do the same as a normal lathe, circular copying is a little harder but the router can do all the work with a step block for the patterns cuts and the router bit will do the rest of the work..
You would mount the stock to the lathe with a sub.block on the head and a longer rod going to the tail stock..on a dowel rod so to speak...I have not done it but want to try it one day..
post #9 of 15 (permalink) Old 05-02-2011, 02:29 AM Thread Starter
First Name: Gem
Routing on a Conventional Lathe
I agree that this is possible, though you would have to be careful of the higher turning speeds of the workpiece. Most woodworking lathes do not have the very slow turning speeds that a metalworking machine will have for thread cutting.
Unless of course you are using a pole lathe!
Hi
post #10 of 15 (permalink) Old 05-04-2011, 05:25 PM Thread Starter
First Name: Gem
Hi everyone - especially Bob and James,
thanks for your help. I have had the brainwave I needed, and will be constructing soon, unless of course some person comes along and wants their entire house painted.
I will let you know what goes on and any preliminary sketches etc.
Essentially I needed to combine the eccentric and longitudinal movements but I could not think of a way to do it, which I now have. When I have made it, there will probably be a more elegant solution, but for now I have a start.
Happy routing, happy woodworking, Gem
Human Verification
turning green wood jdmule Woodturning and Lathes 19 05-11-2011 09:29 AM
Wood turning, General woodwork and Instructor iLovo Introductions 2 01-21-2011 06:47 PM
Turning Wood Hauler BernieW Woodturning and Lathes 17 01-27-2010 08:51 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 06:58 PM
RouterForums.com Holiday Contest - Vote: Wood Turning Mark Contests Archive 2 04-20-2007 01:05 AM
